billconner
Installing t&g porch ceiling and plan on installing 9 canless wafer lights. I've ordered them from nuwatt. These have separate junction box with driver and cord and plug connected water.
Code wise is it perfectly acceptable for that box to be laying on ceiling? Is it required to be able to fish box out of hole cut for water? I presume we so as the means to service it. I ask because 2 lights are directly under a double 2x6 ceiling joist. I could preposition box and install water after ceiling but suspect that isn't code. I'll probably notch joists enough to get box in and out. Not too deep of cut since I have furring under joists. Thought I could set a pair of 2x4s on top and plate sides with plywood or sister a 2x4 on each side with timbertek screws through.
Stupid question but if I preposition the NM-B, should I leave an uncut loop or ok to cut and leave 2 ends at all but last fixture? I need to see one box but believe they are designed for two cables and probably have wago connectors for 3 wires.
