Led light bar wiring help need for my rtv
GophersGarage
Ontario Canada
Hi guys so I have a new kubota and wanted to order front led light bar for the top of roll bar.
either in
36" 234w 16amp
or
28" 180w 15amp
so my question am I safe with the 12 gauge wire I already installed?
green circle location of light bar
orange circle aftermarket 20amp light switch
yellow circle battery
starting from light bar we have purple wire going to light switch
once at switch we have green wire going to battery to get power.
this is approx guess of 25ft wire
blue is ground wire from light bar to battery (neg)
this is about 10ft of wire
ry%3D400
I want to see if I am safe with my thoughts because oniine searching showing me many different versions of wire size to use.
thank you very much for your time
tfi racing
Cedar,BC
The #12 is fine but you will quickly kill that switch.You will need a relay ideally mounted near the battery.
manwithtools
Lebanon, TN
Yep, need a relay rated at 30 amps - available many places.
Use the switch to control the relay mounted near the battery and all is good. I have a 42" on my X1120D facing the front and a 12" facing rear. They work great and are both controlled by switches on the dash and relays near the battery. You also need in-line fuses to protect the relay and switch wring.
G
GophersGarage
Ontario Canada
yup ok thanks guys I will get a relay and not worry about it. most likely wrap in a zip lock bag with zip tie to keep water out incase.
I also have 2 rear leds 18w 1amp each but these are not relayed since to small. I have the 20amp switch I don't think it should be a issue.
as to your 1120. you have 42" dam I seen vids of 36" how bright they are your 42 must be crazy bright :) can you post pics of you install?
I am still undecided which front light to buy
manwithtools
Lebanon, TN
Oh it's bright, so bright I've not found a way to take pictures of it with the light on without blinding myself. I got mine to help with dong work after dark. It works great for that. Mine has spot coverage in the middle and flood at edges. I'd like to try it feral hog hunting sometime. It came from eBay ~ $135 and so far so good. Spends most of it's life indoors though.
66HertzClone
Long Valley, NJ
Skip that Zip Lock bag thought and do it correctly, use one of these then you will not have any trouble.
SuzukiGS750EZ
I agree with all of the above and second the marine relay. That's what they use on most car harness's for any under the hood electronic plugs. You'll be fine with that. You could even install your own breaker/fuse panel somewhere out of the way if you were planning on adding other accessories to it later on to help with wire clutter and ease of diagnosis/installation.
66HertzClone
Long Valley, NJ
Those are what you want to use, both are weather sealed, in the environment they will be in it is the only way to go unless you enjoy fixing it all the time.
-Brent-
Utah
That diagram is perfect. I am going to share it with a buddy that was just asking about these relays! Thanks.
