LED replacement bulb for T3 Halogen Bulb
Ralf11
At least I think they are T3 type bulbs. These are the long thin "tube" bulbs that get blazing hot and set the garage on fire if anything is close to it.
I put up a bunch of el cheapo work-lights for overhead garage lighting about 20 years ago. They up about 12 foot high on the walls. It worked fine but I'm thinking I could put up LED bulbs to replace the halogen tubes as they burn out -less cost to run and less ladder time for me.
But I can't find any LEDs to replace them with.
Any ideas?
pmiranda
Austin, TX
Yeah I’ve had good luck with super bright leds. Be sure to check the L70 rating of what you buy. 50k hours should be reasonably priced and will last pretty well
