jav
I've read most of the posts on these LED shop lights but I still don't understand some things (a lot of things actually).
I understand these lights project more directionally- (not all around like typical fluorescent tubes). Some list a projection angle of something like 120 deg.... which I presume is +/- 60 degrees from vertical but is this only along the long tube axis or is the same +/- 60 degrees projected off the ends as well?
I've also read about flickering/pulsing and noise (audible and electric)... in a non ballasted LED tube- why would there be any of these issues?
I have some LED (array) lights and I do have some individual LED's within the array- that have failed. Most light up- but not all. How likely/common is this on tubes and when would 1, or X number of individual LED failures constitute a warranty replacement..if ever?
