Left handed drill bits
ovilla
Plainfield, IL
I've got a couple of broken exhaust studs and I'd rather not use easy-outs since they always seem to break. Anybody know where to get a decent BIG kit that has all of the most common sizes?
joedodge
Tampa, fl
Ive got a set off the tool truck that are about done the last time i was at northern tool they had a nice set for 30 bucks im gonna get next time im there.
Bruce Amacker
Cleveland, Ohio
Left handed bits are only used when the stub is loose in its threads, like broken off when installing. I doubt they'd be of help in your situation.
rslaback
Westcentral Wisconsin
I use mine all the time when the fastener is tight. I figure if I am going to need to retap I need a hole to start from anyway. A lot of times the fastener does unthread even when it had been tight. Sometimes even after I have worked my way up in bit size as I usually start small and work my way up to tap drill size.
-Brent-
Utah
The only stuff I've ever broken and had to drill out was seized stuff. I never use Easy-Outs anymore. A lefty bit, like mentioned above, is how I go. I'd say 1 out of 4 I've got to Heli-Coil, the others come out.
To the OP, I'm not sure the manufacturer of my kit. It doesn't have as many as my right-turning kit, though.
mikeceli
I just ordered the Irwin left hand drill bit set and the Lisle 4 pc screw extractors.
I have never owned LH bits, now I'm LESS LIKELY to break a bolt.
cj7365
New Mexico
^^^this all day long^^^
318fekim
Seffner, Florida
If you have it available heat the manifold around the bolt first. Ive done this with much success and now if its off I do it and replace even with good studs to prevent breaking when tightening.
Griff93
Huntsville, AL
If you're trying to get some exhaust studs out of a type IV head that are broken, good luck. You're best bet is to weld a nut to them.
FunkyfullWidth
Three Rivers, ma
I broke just about all the studs on an exhaust manifold for a cat motor once. Alot of them had enough meat left for vice grips, a few snap clean flush. I have a snappy left hand bit extractor set. Very nice, wish i bought it a long time ago. drills have worked on everything i've thrown at them so far. the easy outs worked good too. A few of the studs I needed to weld a nut to, or weld a nub on so vice grips could grip.
Bob C
Just remember to run your drill in reverse. I sold a guy a set and he came back ticked off. He claimed they were not good quality as they were burnt on the ends. After I questioned him a bit, he never reversed his drill and tried to use LH bits in a RH direction. Thats a OOOPS!
DrkMtnDew
I've got a SO 35pc. set that is real nice set. Also got an ATD that has been a really good set and the price on it was great. 5pc set for $4 from my local parts supplier.
