Hello all,
Big thumbs up to Legacy for supplying quality coatings on this 60 year old 400 sq. ft. tandem garage floor:
1. Oil stop primer
2. Primer
3. HD epoxy with full flake, 1/8 in. Stonehedge
4. Two coats Polyaspartic-80
Stem walls were coated with epoxy for vertical applications recommended by Scotty followed by flake and urethane. Spalding corrected with Legacy's Gel Crack Filler followed by grind. Flake application followed by quick sanding with 100 grit screen prior to polyaspartic application.
Lots of cash went to Legacy but end result is worth the outlay. Hope to get a free tee-shirt from Scotty to help make up the difference
1. Oil stop primer
2. Primer
