Legacy Industrial - Bronze / Mahogany + Polyurea
dcg9381
Austin, TX
I like how it turned out. I've used polyurea in my commercial building and it's been great. This is a "garage" area that also doubles as a game room.
It's legacy industrial water based stain - Bronze with Mahogany accents / highlights... First time I've worked with water based stain, which was a little challenging for me.
I'm going to try the same thing in the main garage with Legacy stain and HD6600-MMA.
Steve in UT
Would you mind expounding on the whole process? It looks great! I would especially like to know how many coats of polyurea and did you prime or not?
D
dcg9381
Austin, TX
Steve,
I didn't prime it. I've had no adhesion issues with "new concrete". I'm doing 2 coats here, but it really depends on how porous your concrete is... My shop only has one coat.
I'm working with "new concrete":
  • Let the concrete dry fully
  • Do surface prep (Remove any glues, masonry, stuff that gets on it from construction)
  • Clean it - blow it out, blow it out again, sweep it, wet sweep it, wash it out, wash it out again
  • Final cleaning - ran robots over it for about 2 days
  • I used Delta Dye - which is a spray on water based dye - easy to use (get some practice first)
  • Let dye dry 1-2 days
  • Apply polyurea - I use a small roller on an extension and go around all permeters in all room, then use an 18" epoxy roller to coat in polyurea - assume the first coat will take a lot of material
  • Coat again (optional)
  • Enjoy
The floor looks great! Just curious, why chose a MMA sealer instead of the polyurea in your main garage?
My shop has polyurea. MMA is less expensive than polyurea and is UV stable. It's simply a cost thing. Most of my "work" is done in the shop, not the garage... I think polyurea is a better option for working garages.
