Legacy Industrial Spring Discount Code
L
LegacyIndustrial
deerfield, IL
What a sweet deal! Now is the time to invest in a new floor coating.
Personally, I can attest to Xtreme Set 100 for filling cracks and divots in concrete floors. Very fast turn around and can be used in cold weather applications.
Thanks sir!
Here is a quick How-To video on the product...
Manganos
Virginia
I was a day late but my products arrived quick! I am going to make a new post with a few questions maybe you can help me with ! Thanks again
L
LegacyIndustrial
deerfield, IL
Nice video! Initially, I tried this method of filling the joint fully with sand and then adding the Xtreme Set 100. My experience showed that when using this at colder temperatures the Xtreme Set 100 took longer to soak in, so to be sure I got full saturation and bond, I would do a half fill of sand to start which worked really well.
We changed the formula recently. This version penetrates through the sand faster and more evenly.
L
LegacyIndustrial
deerfield, IL
I thought the color of the mixed product in your video looked lighter in color. Now that makes sense.
We needed a product that would be useable during the concrete polishing process. The other formula did not look great without a coat of epoxy over top.
Revtor
Northern NJ
Scotty, can you put flake into a wet application of "standard epoxy primer/coating"?
Looking to do this coating (tan) over cleaned/etched 50 yr old concrete with a urethane topcoat.
Also, is there a way I can see larger images of the color flake combinations on your site? Some combos have names but no way to know what they are?
thanks.
~Steve
Edit - just found slackdaddy's post. http://www.garagejournal.com/forum/showthread.php?t=358712
This is exactly what I want to do, same colors even. guess it's doable!
L
LegacyIndustrial
deerfield, IL
Yes. Glad you found it.
Most of our kits have a downloads tab where color charts can be downloaded. Also have some nice examples in the gallery.
