Lenco Panelspotter Repair
dda402
Just gathering thoughts on how to repair my Lenco Panelspotter. Where the cable is swedged into the end, it has broken about 1/4 of the way through the wire. I was thinking of cutting it off and bolting a lug to it. Cable is 4/0. Any thoughts on the repair of this item would be helpful. Maybe I'm worrying about nothing - my thought is that I am losing current. I only use this spot welder occasionally for auto panel replacement. Thanks in advance for any help.
D
dda402
No, I did not fix this as yet. Lenco wants $300 for new cables. That's a little more than I want to spend. A guy on a welding forum recommended cutting it off and brazing a welding cable connector to it. I also thought about getting a copper rod and making a new end. Any other thoughts would be appreciated.
rlitman
Long Island
If you can deal with a shortened cable, then I can think of some fixes.
If the end is still fine, you should be able to use a drift to open up the end that the cable fits in, and extract the cable. Then shorten the cable, torch anneal the copper end (before crimping it), and then use a hydraulic crimper to re-do the connection with the wire being shortened an inch or so.
It might make better sense to cut the wire and anneal the copper end before you even try to wedge it open, if you think it's too hard already and might crack.
But I doubt that the loss of just a few outer strands is all that important.
D
dda402
I like your plan. I never thought about annealing the copper to make it soft. I will be trying out your plan this weekend. Thanks for the help.
fitter30
Peace Valley,mo
Cut the wire off of the electrode find a copper sweat coupling or a short copper pipe close to that size. Solder 1/2 coupling on the electrode the other half to the coupling. Would tin both sides to make soldering easier.
wazzabie
Have you tested the ohm resistance of the cable? Is the tip about to fall off? If you were to just tape it would it be usable?
kabinenroller
S.E. Wisconsin USA
Were you able to repair the end? I would be careful of a bad connection if you leave it as is because it would create resistance which would create heat in the handle where you hand hold the “stinger”.
I have a Lenco Spot and when I use it continuously for multiple welds the handles get hot.
It is a great machine and makes good strong welds.
wazzabie
What size breaker do you run for the Lenco panel spot welder? I recently acquired the same welder.
rlitman
Long Island
Have you tested the ohm resistance of the cable? ...
If more than a couple of strands are connected, any multimeter will read 0 ohms. You need a micro-ohmmeter to get anything useful out of this, and even then you'd need baseline numbers to know what's going on.
wazzabie
I have the same lenco spot welder if that could some how help. I just have a regular ohm meter.
RPH
Michigan Thumb
You can use a low voltage but 30 amp dc power supply. Measure the voltage drop across the cable. If it’s more than one volt, then strands are broken. Time to fix at that point. We use this technique on the high frequency cables with induction equipment.
D
dda402
Here is an update of what I have done. I checked the voltage drop - it was 1/2 to 3/4. I cut one of the ends off and removed the wire. I heated the end up until it was cherry red and then left it cool. I managed to hammer in a drift pin. It cracked slightly but I don't think it will matter. I am currently waiting for a crimping tool I ordered. The wire is a little green from corrosion. I am going to clean that up and try to re-crimp it to the end. First, I will heat it up again to make sure the end is soft. Thanks for all your help.
toplessHO
central florida
without cutting can you slide a piece of thick wall copper tubing over the stinger and the wire? If so strip back a portion of insulation,crimp wire and crimp pipe to the stinger.
DON@38PLYMOUTH
massachusetts
I just picked up a older Lenco Panelspotter from a body shop closing as is I knew the shop,and it used to work for them. There not around anymore for me to talk to. So i have power into the machine going through the 60A cartridge fuse but nothing happening after it Anyone out there able to diagnose this. thanks
californiamilleghia
SoCal
I have one out in the garage , are there any copies of the manual on the net somewhere ?
Not sure what model it is , all I remember it was green !
