cvairwerks
We've got a Lennox 13HPX system that was installed about 10 years ago. It's been reasonably trouble free until last year. We started to get random low pressure lockouts on it. We had the coils cleaned, charge checked and it seemed to quit for a few months. Starting in March, it began again. Tech checked charge pressures, verified them by the in unit charts for the configuration we have. In April, after it happening several times of a weekend, we had the tech out again and everything was within book numbers. The only thing he noted was a tiny ticking in one bearing on the condenser fan. Not bad enough to change, but something to be planning for.
Fast forward to June and the unit is going into lower pressure cutoff numerous times a day, like as many as 8-10 times. AC company owner had told me how to reset things back in March and said that they were starting to get more and more calls for the same thing. He suggested that if it continued, that we would need to swap the control board. Got frustrated enough last week and ordered a new, upgraded board and swapped it out on Sunday. Unit worked flawlessly til last night, when it started to go back into low pressure cutoff again.
I know if we get a slight power spike or droop, it will send the unit into this mode. Any idea of any power conditioning I can install in the unit to maybe stop this? The wife and youngest son are tired of having to go cut off the breakers, wait for a couple of minutes then reset them so the unit will reset. This is getting to be a huge problem as summer heats up and I'm not where I can drop $20K to replace and upsize the system right now. Nor could I deal with having the hose torn up for a week to do all the work it would entail.
