signcrafter
- Joined
- May 9, 2012
- Messages
- 12,497
Have a lennox surelight that has been working fine and came home tonight and thermostat was blank and no heat. When I open up the furnace both green LEDs are flashing slowly which means operating normally according to the chart. The thermostat is a honeywell home digital wifi that I put in a few years ago. Thinking because the LEDs on furnace are saying normal and thermostat has no display that the thermostat is dead. The thermostat has no batteries. The only other thing is there is an amber or orange LED that says hi/lo by it that is on solid, not sure if that is normal or not? Is there a way to "jump" the thermostat wires to get the furnace to turn on so I can test if it is the thermostat or not? Going to bed for the night and hoping I don't wake up as an icicle. I did turn the shop heater on and opened the door so it's staying around 55 degrees for the night so should be fine. Planning on running to town in the morning to get a new thermostat unless someone posts different on here tonight. Thanks.
