Spudland_Dave
I know...vague as hell title....last night I wired up my Sub-Sub Panel using the 4ga THHN, my question is on the Neutral and 2 Hot lugs in my panel, the wire once I tightened down the lugs is quite smooshed and some of the strands are not under the lug. I attribute that to the lug being so large and cable relatively small. On the "Feed End" where that 4ga THHN goes into the 60A Breaker its beautiful and perfect. I tried a couple times, outcome the same. Lugs are rated for 4ga, so no technical/code problem there. Being a little OCD, it looked less then perfect so I figured I'd ask about it.
