Less then Neat Wire Termination under Terminal
Spudland_Dave
Maine
I know...vague as hell title....last night I wired up my Sub-Sub Panel using the 4ga THHN, my question is on the Neutral and 2 Hot lugs in my panel, the wire once I tightened down the lugs is quite smooshed and some of the strands are not under the lug. I attribute that to the lug being so large and cable relatively small. On the "Feed End" where that 4ga THHN goes into the 60A Breaker its beautiful and perfect. I tried a couple times, outcome the same. Lugs are rated for 4ga, so no technical/code problem there. Being a little OCD, it looked less then perfect so I figured I'd ask about it.
theoldwizard1
SE MI
If twisting tightly with linesman pliers doesn't help, you could try "tinning" the end with solder, but unless you have a really old fashioned heavy duty iron, you will likely get a cold joint.
SiGmA_X
Portland, OR
I'd re-twist with your linesman pliers and see what happens. I've only installed a couple runs of 3-4ga before but it all fit under the terminals completely.
S
Spudland_Dave
Maine
I did that on the worst one...what ends up happening is because there is no "Side Support" for the wire (1/4" wire diameter in a 1/2" lug hole) the wire just smashes down quite a bit under the set screw...Even as twisted tight I could get it. Now I'm at the point where I'd hate to damage the end.
Rob_b
Ontario Canada
You could always use a ferrell (sp) on the wire end before putting under the lug. It sounds as if the lug is rated for minimum of #2 or larger if its spreading out that badly. Short of that, go with tinning it up. That will also keep it from over-heating on a large load.
SiGmA_X
Portland, OR
If Aceman says its OK, I think its probably fine. The man quotes NEC like its his job (I think it is ;)).
Maybe post up a picture so someone can give some feedback based directly on what they see vs a description of it?
S
Spudland_Dave
Maine
Here ya guys go...I was thinking the same thing, by the time I/we got the kids to bed, I get out into the shop, etc you beat me to it :D
As you can see...I took the neutral off the lug tonight and put it directly on the Neutral bar...fits like a Glove there.
Main & Neutral Lugs are rated #6-1 on the panel sticker. Ground & Neutral Bars are #4-??
