snapmom
Florida
I still have some of my dad's tools too. They are quite special.
The box may have the model number and date code stamped on it, take a look all around it.
bluebolt
Benton LA
Picked up this WWII A-59444 long 3/8" drive ratchet a few months back. No Snap-On markings but Snapmom identified it. Snapmom is about the only person I could find that has posted information about this model before. Date code is G. Ratchets OK by hand but you can see the drive gear has a few teeth in poor condition.
bluebolt
Benton LA
Nice find, bb. Classic handle shape and Snap/on date code placement in the selector panel. Speaking of the handle, what is that, a hole?
Yup it is a hole. Don't know if it as drilled by Snap On or more likely an end user. If it was used on airplanes it may have been "tethered" for working in certain areas where a dropped tool was nearly impossible to retrieve.
Username already in use
Picked up a few vintage SnapOn goodies today. 1/2" drive '45 dated ratchet and a '45 dated F-16 swivel socket.
I have that same box with a different label placement. My Dad bought it in the mid-50's when he worked as a mechanic at a Chrysler dealer, but I don't know if he bought it new or used and he's been gone for over 20 years, so I can't date it.
My Dad called it his "ignition box", as he carried all his 1/4" drive stuff in it, ignition wrenches, ignition point tools, as well as some points and condensers when he'd make a road trip to do a tuneup. Many a night or weekend I'd carry that box as a child, while he toted his timing light, tach/dwell meter and other tools in a larger open tote. After he passed away, I loaded it with all my 1/4" drive stuff, tucked it into the bottom compartment of my roller cabinet and use it to this day. I don't visit his gravesite often, but that box and his two-drawer middle section incorporated into my tool cabinet are all I need to rekindle memories.
Bill
I still use some of my dad's tools as well. They made that stuff to last!
LesserSon
PA USA
Picked up these eight S/O overstrike ½dr 6pt sockets today.
dkroth
Rochester, New York
What year was the 'CA' catalog? It's not terribly vintage, but this is the group who will know. $1 at a garage sale.
LesserSon
PA USA
Came across this today at the flea market. RS1012 “ratcheting open end” Blue Point Supreme. No date code that I can see.
snapmom
Florida
Here is a set of 7 with 48 codes. Also some odd balls with no date codes.
No date codes on these
Just bought them cause they looked cool! Thought it was odd no date codes. 55 catalog shows them as a set for industrial maintenance, but gives no individual model numbers. Then on next page shows same wrenches in pouches but they are bluepoint!
These are some sockets with double/over stamped date codes of 37 38 and also a couple of whitworths I got in a set from australia.
RagTopTA
Wichita Falls , Texas
I picked this fella up at the flea for a dollar this weekend. what are these little socket type wrenches called?
Ole Slewfoot
Freedom, CA
Walden 'tomahawk' series, and Blackhawk too.
I thought I'd posted the one got awhile back, but it looks like I need to take a pic.
Ole Slewfoot
Freedom, CA
1930 model 7/16 and 1/2 hammerhead double socket wrench with a 1940 slide bar.
The Walden patent
HobbyistWolf
Washington state
I have an vintage 1/4 Snap-On set from my grandfather, it consists of 8 sockets, a 6-inch extension, a driver with an orange plastic handle, a sliding T-bar, a unmarked/no-name breaker-bar (presumably added), a modern Thorsen 77M ratchet (added), and a vintage Bonney RF22 refrigeration ratchet converted to 1/4 drive by the addition of a piece of 1/4 square bar-stock held in place with two nails acting as cotter pins on either side of the ratchet head. All Snap-On pieces have an E after their part-number. Pictures here: https://www.dropbox.com/sh/u33vpnmbzbjeiw3/AAC6DHiKTYHPhc_NLE9vD2cva?dl=0
Here is my Walden version.
Here are a some more snap on versions. It appears the sockets were cross drilled and then plug welded from the top, perhaps to avoid the above patent
There was a thread on the hammer head wrenches a couple weeks ago.
https://www.garagejournal.com/forum/showthread.php?t=391771
Here’s what I learned on the age:
“After some research in the Collecting Snap On catalogs, I think they were first marketed in 1927.
-1927, part of the Ferret 3/8 socket set, which included just two wrenches 7/16x 1/2 and 9/16x 5/8.
-1928-1931, now three wrenches listed. 7/16x1/2, 9/16x5/8, 11/16x3/4.
- 1932-1938, only one wrench available. 9/16 x 5/8.
That’s what I found with the catalogs available on the site. What a great resource as always.”
