- Joined
- Nov 4, 2017
- Messages
- 10,472
Knocked the rust off this today and had no idea it was a snap-on.
on Flickr
Sorry for the delay, don't check this thread very often. If the part with the female threads has a divot on the end opposite the bolt, it's probably for popping ball joint studs out of spindles. I made a similar tool, works good. You would loosen the nut on the stud you wanted to remove a couple threads, insert this tool between the 2 ball joints, and use the tool to pop the stud out by opening it up.How about an adjustable front end suspension tool date stamped 1964.
Can’t picture its use..
Catalog describes it as adjustable height for Ford, Mercury, Lincoln, Plymouth, Desoto, front end work on ball joints,spindles, coil springs, control arms.
Picture looks like something else
Lucky. That is a highly desireable rat. What did you have to give for it so I know how jealous I am?Picket up this odd ball Snap on L67 ratchet at a flea market this weekend. From what I found it was built under government contract and has the cadmium or zinc plating typical of the WW2 era production. The patent was issued in 1934, but it doesn't have a date stamp indicating an early production model.
http://www.collectingsnapon.com/index.php?page=socket_sets/1-2inchdrive/HalfRatchet
Sent from my XT1080 using The Garage Journal mobile app
The logo (50's into 60's/70's) is not my collecting era, but I definitely plan to wear it!
From 1920, the first tools they made, famously advertised as "5 do the work of 50" (in reference to the 5 handles times x the 10 different detachable sockets).Its called "the original set"
I picked up this Blue-Point Supreme flat chisel set in original leatherette roll-up at my double early bird flea market this morning.
Too much rust to make out the markings clearly, and I haven't really inspected it closely yet, but I suspect this is a late 1940's No. SC-50-K set, with S-812, -816, -820, -824, and -828 chisels, although that funky one is either something else or the S-824 has been modified.
I'll post more photos after cleanup tomorrow.
You may want to re-calibrate whatever you told Len, because Snap-on/Blue-Point moved to that new logo that you're showing in the 1950 catalog between 1947 and 1948. My chisel set with the identical logo on the inside of the roll-up is on page 55 in Catalog S (1948). Link here. But I will check for date stamps tomorrow.
I don't know about that, but I did remember that it was a late 40's transition. I have my quibbles with some of the write-ups and conclusions on Collecting Snap-on, but the catalog section is amazing. I wish we had a multiple mfgrs' library set up like that. The way it's linked to the model number database is brilliant, and my favorite feature (after the magnifying lens). I am sure you already know this, but once you identify a tool in any catalog, if you go down to the list on the bottom and click on the model number, it will show you all the catalogs it ever appeared in. That will give you a range, so you can easily find out when a tool was first introduced, and when it was discontinued. Generally.You are still the research king!
No doubt. That wasn't a critique. And beggars can't be choosers! The TA library was awesome!I simply didn't/don't have time!!
No doubt. That wasn't a critique. And beggars can't be choosers! The TA library was awesome!![]()
