Lets see those work related injuries.
Roberts210
Missouri
This is not me. Evidently the E.R. docs just pulled the nail out and watched the guy for awhile. They say there is no long-term damage.
Maui
Upstate NY
I was working on an old Ariens snowblower a few years back. It was covered with so much rust that I felt like I needed a tetanus shot every time that I used it. It was running rough and I figured that I needed to make some adjustments to the carburetor. In the process of doing this I had to disconnect the fuel line. I thought that I had shut off the gas before I pulled the line, but apparently I neglected to do that. When gas came spilling out it startled me so much that my hand just automatically jerked upwards and banged into the machine. After I shut off the gas and cleaned up I noticed that my thumb looked odd. Closer inspection revealed that a thick shard of rusted metal had impaled itself into my thumbnail. It was imbedded through the nail but didn't touch the surrounding skin, which is probably why I didn't feel too much pain. I knew that going to the doctor or the emergency room would be a royal waste of time because they wouldn't do anything for it anyway. But they would charge a ridiculous amount of money that would come directly out of my pocket. And my high deductible plan wouldn't reimburse me for it. So screw it. I pulled the chunk out with a pair of pliers which removed the vast majority of it. But there was still a significant amount of debris imbedded in the nail and the flesh underneath it. So out came my old Black and Decker dremel with the flexible cord. I have a microscope at home that I looked through as I used a sterilized grinding arbor in the dremel to very carefully grind through the thumbnail. No painkiller for this either. It wasn't pleasant. Then a sterilized sewing needle was used to get the little pieces of rust out of the remaining nail and underlying flesh. It was a nice bit of dremel surgery. I even took some photos of it afterwards. I'll see if I can find one and post it. The end result was that it never became infected, healed completely, and since the nail has grown out you would never know that I was ever injured.
Maui
JBradley500
This is one I actually have a picture of. Got carried away with my hammer swinging.
RRmech
Santa Fe, NM
Broke my left hand in 1988.
Slipped and fell flat on my back on a small patch of bearing grease, while carrying a commutator bearing cartridge.
Cartridge went flying straight up into the air.
Then straight down, and landed on my left hand.
Steve
pepgj
Hopefully no one starts posting those pics of lathe injuries.
