Let's See Your Chainsaws
bulletpruf
San Antonio
OEM piston finally showed up and I checked squish with no base gasket - .012" - too tight.
The factory gasket is .019" so I could do better than that. A paper grocery bag is .006" so that would still be a bit tight, I think. I also have some gasket material at .013" that would be better than .019", but only by a small amount.
Thoughts? Just not sure I want to go through the trouble of cutting a new gasket if it's just .006" difference.
Anyone have any thoughts?
bulletpruf
San Antonio
I just went with the factory .019" gasket. Squish is at .031" and I'd rather be at .020" or so, but I'm not going to lose sleep over .011" more than I wanted.
Aaron_W
I could have sworn I replied to this thread before, but I just read through this whole thread and nope (BTW some of you guys have crazy collections). There must have been another I replied to.
Well I just doubled the number of "collector" saws I own.
Soon after getting married and buying a house I bought a used Stihl 041G in 2000, to use for cutting firewood. We didn't have a lot of money to buy a saw and found an older guy who was giving up on cutting his own firewood so sold the saw to us.
I bought it to run it, but being of an older generation of saw it isn't the most ergonomic saw to run. Heavy, loud, awkward operating position, no chain brake and no vibration dampening.
It was fine when we just burned 1 cord a year, but a few years later we moved and were cutting 3-5 cords, plus we were doing a little better financially so upgraded to a new Stihl 390. I ran Husky 372s, Stihl 360s or 440s at work, but I couldn't justify the cost of a pro saw for cutting firewood. The 390 has been great.
The 041G was too neat to get rid of so that was the beginning of my small collection.
We don't have a fireplace in our current house, so the 390 got downgraded to doing occasional yard work. Overkill, but I have it and it still works great. I bought a small Ryobi cordless saw (12" bar) a few years ago, no mixed fuel to mess with, and it does fine for most of the yardwork which is mostly pruning or cutting up the occasional downed tree limb. About the only time the 390 comes out anymore is the rare occasion I need to take down a small tree.
I have an old fire engine (1958 Dodge W500) and have been wanting to get a period correct saw for a 1960s brush truck. Although I have the Stihl 041G, that is way to exotic for the 1960s American fire service, so I've been looking mostly for Homelite or McCullough. Primarily I've been looking for an early Homelite XL-12 since they were so common and generally fairly cheap. The early blue painted ones are less common though, and that would be the most accurate.
In my searching I ran across a Homelite Super Wiz 66. It was in decent condition, the price was right and it just looks neat. Plus SUPER WIZ. :D
It is a gear drive, and came with a 36" bar on it so it looks rather impressive and will be a nice piece on the engine. Also kind of a nice example of how far saws have come since the 1960s. It is basically the size and weight of a Stihl 661 with the displacement of a 461 and the power of a 362. Granted the gear drive should give it some pretty good torque for the horsepower generated.
In nice shape, but the seller said it hasn't been run in some time. Everything moves freely and the dirt and grease doesn't look ancient, so I'm hopeful a little cleaning and some fresh fuel will be all it takes to get it running.
Stihl 041G, 61cc with a 24" bar. In production from 1969 to 1975 and one of the few gear drive saws Stihl offered.
The newest arrival, the Homelite Super Wiz 66, 77cc with a 36" bar. In production from 1965-1983. Also a gear drive and it runs on 16-1 fuel mix so I expect it will be a smoky guy when I get it running.
rd65
Granite Falls, WA
Be sure to take into account the oil that they used back then when deciding your ratio. Oil then was much different than the dino & synthetics used today.
Aaron_W
Thanks for bringing that up. I did some looking around and apparently a lot of 2 strokes asking for 16-1 were before commercial 2 stroke oils were common and they assumed mixing plain 30w oil with the fuel. Later Homelite called for 32-1 when using their "special" oil.
The Stihl 041G is only a little newer but it wants 40-1.
bulletpruf
San Antonio
That 041G is a keeper. I've had a few of those.
Homelite's are generally inexpensive, so that's a great way to accumulate several vintage and somewhat collectible saws on short $. Concur with the recommendation on oil; I generally run my older stuff on 32:1 or so.
rd65
Granite Falls, WA
The important thing is finding a ratio and brand you like and sticking to it as it can minutely change jetting. Personally, I run Yamalube 2R at 40:1 with super unleaded (I dont go searching for ethanol free). I add Stabil to all my fuel that i put in gas cans.
Gmonkee
Husqvarna clones sold under a million names, 45cc and very good saws. Easy start and reasonable power.
The seller has excellent in house service if needed. No worries for downtime, the 2nd is my insurance policy to finish outside jobs.
I haven't needed it yet.
The yard saw is the little B+D corded. Usually on a 10" bar but I have bigger.
I use that one for keeping the big ficus at bay. It would take over the entire yard left alone.20260723_120011.jpg
soloz2
Western NY
I have my father's saws. I use them occasional. But they both run great once you get them started.
But for around the house this gets used most of the time.
I’ve had the m12 hatchet since shortly after it came out and love it! It gets used for pruning large branches, low branches, storm cleanup etc.
few years ago we had a big storm that downed trees. I have it to my FIL and told him to have at it while I worked on the larger stuff with a chain saw.
Nofries
Charlotte Area
It actually is my wifes hatchet. LOL
Se saw it and said oh how cute I want it. First time we used it for limbing up our trees with a 6.0 battery. It kicked my ***. the battery lasted longer than expected so I didn't get a break I would have liked.
Gmonkee
I am teaching my son the arts of man with stuff like chainsaws, big gas trimmers and circular saws. To know them we have to own them too.
All my wife can ask is "is it dangerous?"
Well, yeah. But somebody has to have the smarts to use them in the future.
She barely likes using a battery trimmer.
