let's see your craftsman block grinders
drivesitfar
Outlaw: thanks for noticing my switch and outlets that need covers and i probably still have baby plugs in a box someplace. i know I own maybe 50 covers and every one inside the house was covered and with a baby plug in them for years while raising our 5 kids.
since we never put pop in the garage fridge the kids would rarely spend any time in our garage except to get in and out of my wife's car. there used to be a cabinet in front of these switches until i put the hanging organizer up a couple months ago and the bottom organizer below. i wanted to put my baldor buffer down below on a stand with wheels, but it would be in my wife's access to and from her car so that wasn't going to fly.
Jake and Bagged: i don't like the look of that 3/4 Block either and i'm waiting for a 3/4 or 1 HP if they made one to match my 1/2 HP commercial block as it appears.
jakemac
New England
Yeah that one has been listed for like a month now. I tried to convince the guy to meet me closer but he never responded. The. I lost interest in the 80s style block.
It's not that far from me, I could have picked it up and put it on the Garage Journal Pony Express to get it to you. I've been watching it since he first put it up on CL but I didn't post here it until today because I kept pondering whether I was going to go for it or not. In the end, like you, that styling just doesn't do it for me.
bagged89s10
CT
Thanks. Now I decided to only look for older blocks with metal eye shields.
bagged89s10
CT
That heavy quench tray and rests were a separate option that could be put on any size grinder. Same as the stand.
I also saw another 1/2 hp somewhere with the heavy tray and rests. Maybe it was the same one on eBay.
jakemac
New England
Another tidbit on the heavy quench trays -
I think they came in two flavors. The earlier ones were heavier and a little thicker cast. The later ones were a little lighter and thinner walled. IIRC.
Bobioz1
Northern il. (For now)
I have an 80's 1 hp right next to a 70's 3/4 hp. Even if the h.p. was equal the black one looks like it could kick the gray ones ***. They are the same grinder but the black one is just wider.
torqueman2002
Um, I'm thinkin' that light ain't original equipment?:spit:
CL Link
I could see $30 - $40, in SE Michigan; but $70. :headscrat
The bulb sure won't fit under the OEM lamp shade, but the goose neck lamp is OEM/option for m-397.19581, below.
For $90, I picked up this Block and a CM stand.
torqueman2002
Dang. Tewksbury is only 2 towns over from me.....but I'm not in town right now. :(
Call the seller.
Some times they will work with you.
I travel from SE, Michigan to Central NY several times a year. I've had 5 or 6 sellers hold the Block for me, after sending payment (PayPal or check).
Actually, right now a seller is holding on to a Block for me and doesn't want $$ until I pick it up. :)
torqueman2002
Well, I wouldn't call this a pre-Block. What about a prehistoric Block?
Anyway, here it is. I emailed the seller 3 weeks ago and forgot about it when I didn't get a reply.
1/3-HP CM m-115.7397
It is cast iron and must weight 50+ #s. Everything is there, red-plastic quench tray, lighted & chromed eye shields, ....
Thanks for looking.
bagged89s10
CT
Thanks for looking.
Looks like the one okcguy posted a couple days ago.
BlueBomber
Outside Boston, MA
Call the seller.
Good advice, T-man, but Block mania hasn't grabbed me hard enough yet to go to those lengths. That day may come...:). I do like it enough to check on it when I return to see if I can get it for a YS price.
torqueman2002
See my comments/replies in Blue.
Torqueman,
What's the year on this one?
I'm not sure.
More investigation and report soon.
It's not a Block; but it sure is in the Block family -- Great Grandpa maybe?
It sure looks like it, his center band looks to be in better shape. I hope mine cleans up. It's good to know what it should look like.
Give it time. When it does, remember .... you have been warned. :p
That's what keeps me searching.
Good Luck. :thumbup:
jakemac
New England
There is a date code stamped at the bottom of the label under Sears and Roebuck. The last two numbers should be the year.
torqueman2002
See my comments in Blue.
It's probably a 40s or 50s.
Thanks. Looks like 51 from the label, below.
Same motor style on my table saws.
Here is a 50s one on vintage machinery.
http://vintagemachinery.org/photoindex/detail.aspx?ID=6129
Nice!
Found it, 51. Thanks.
Doc: nice old Pre block. it looks like a 1954 stamped in the bottom section of the label?
Thanks, Drives. It may be hard to see from the pictures, but it is E3 51.
This tipped the scale at over 71 #s, as pictured below.
okcguy
Torqueman, that is like the one I posted a few days ago. This particular grinder was listed in the 1948 catalog. It was touted as "new" so that may mean that was the first year it was offered. I have not been able to look at a 1947 catalog to see if it is listed there. However, the 1953 catalog is the last year it was offered. I looked on the back of mine to try to determine what the date of manufacture was. It read L1 47. I assume that means the 51st week of 1947. Just in time to roll out for 1948. In the 1948 catalog it lists the shipping weight at 98 pounds. Some of that would have been shipping material, but the bulk of that would have been the grinder itself. So, when you noted that it was heavy, you were spot on. It is heavy enough that when I bought it at an estate sale, I had my wife bring the car down closer! That was not one I was going to heft up and skip down the street to the car.
Two things about this grinder surprised me. One that it was only a third hp. For the size and bulk, I would have thought around 3/4 or more. The other thing is that after all these 67 years, that red, plastic quench tray is still there and not broken. I noticed that yours was there too. It really is a unique looking grinder.
torqueman2002
Good morning guy, see my comments in Blue.
I have a 'library' of CM tool catalogs, starting with 1940-41-42, skipping to 1948. I think that the 'gap' is due to WWII.
See below for a link to CM catalogs.
I have seen others like these grinders, but missing the quench tray and eye shields. I think we're lucky.
Yes, I like the style too.
The 1948 catalog says the color is: "Finished in attractive Craftsman gray with contrasting chromium trim. Convenient removable built-in water pan of bright red plastic."
Rose Tools Scanned Catalog Archives, now located at the link below.
http://www.blackburntools.com/articles/rose-tools-catalog-archives/index.html
Because there are 32 Sears catalogs in the archives, they are listed on a separate page.
http://www.blackburntools.com/articles/rose-tools-catalog-archives/sears/index.html
Update
Here's a link to a pdf file for parts, etc .... for this 1/3-HP Grinder, submitted about 5 weeks ago. :D
http://vintagemachinery.org/pubs/detail.aspx?id=8421
WhoWhatNow
Collegeville, PA
I think I emailed the seller last night, I'll have to look at my emails (hell getting old and can't remember sh=t )
Edit - I did email seller, no response yet.
It may be worth asking about the tool next to the grinder as well. Looks like another craftsman stand with a motor on top. Could be a belt sander.
drivesitfar
Harley, WWN, Doc, Jake, McB, Ex and others: i bet you can spot a Craftsman original stand from 100 yards. that stand in the right of the picture looks pretty tall too so wonder what tool is on it. this catalog picture might have been posted here before, but while i'm posting a picture doesn't hurt does it to refresh our memories?
harleybuilder
Southern IL
My eyes aren't what they used to be so I can only spot one at about 90 yards anymore. .lol. ... I'm hoping to get a response and pic of the "mystery tool" and go from there.
WhoWhatNow
Collegeville, PA
I'm betting on a repurpose of the stand. The grinder stands are about waist height so that one is pretty tall. I think the stands for larger tool were shorter. I think the stand is just 4" pipe so it shouldn't be too hard to replace with a taller one.
exmaxima1
Midwest
I would agree with you, but I also think the pipe is 3-inch or less. I already checked the CL ads to see if that seller had more ads, cuz that "thing" on the tall stand looks like a Wilton Square Grinder at first glance, but I don't see any.
