Picked up two grinders for $20. One looks complete with coolant trough and light. Second is missing a side cover, and the switch looks to be backward. The name and motor plate are in the back, but the on/off switch is in the front. You'd think they would be on the same side??
so ... worth cleaning up?
The switch is in the knockout for the lamp. I suspect that at some point the original switch died and the owner took the center band off to replace it. Then installed the band backwards to put the switch in the front.
Is there a hole for a switch under the ID plate on the "back" side ?
I suspect this is the right answer.
If they really put the switch in the back, and rotated the grinder to get it in front, they would have to flip the entire guard and rest assemblies (which would then probably not alight as they have 3 hole mounting IIR) and reverse the direction of the motor, which might not be possible on the 1/4. (or needed on a block grinder...)
On the backward information plate one, it look's like the switch is mounted in the knockout where the light would normally be mounted.
The 1/4hp grinders often came with NO switch, and the buyer figured out how he wanted to add a switch.
