Lets see your FIRE EXTINGUISHERS
Boyd
Forney, TX
Fianlly getting a chance to read this thread, now it will go back to the top.
I also have a few more in the garage.
What brand and size are those extinguishers? I've been looking for something similar for my garage.
Also, what about "vintage" extinguishers? Every once in a while I come across one on ebay or at a flea market. Can these be serviced and put back into use?
Jared
Victoria B.C
Boyd, From my experience old CO2 and water extinguishers can be used but old dry chems cant. My CO2 is from the early 70's, I had to have it hydrotested but that not big deal cost about 10 dollars.
NUTTSGT
Northern Central Ohio
Those are just old ones that I have aquired over the last few years. The one second from the right is probably the only one that could be put back in the service.
I do know that the 2 on the right do work.
Charles (in GA)
50 mi south of Atlanta
Thought I'd bring this thread back to life.
I have four extinguishers in the shop now. All are 10 lb units, all dry chemical, all have metal valves (don't buy plastic valve extinguishers if you intend to have them serviced, no one will service the plastic valves).
One of mine, a short/fat 10 lb Badger lost all of its pressure, so I figured I'd take it and have it serviced. Two of the four were bought at the flea market at different times for $10 each, and had pressure and the powder moved inside when you shook them, so I figured they were good. It was one of these that lost pressure. The service sticker that was on it showed it was 10 years from the last hydro test and inspection, so the shop did another hydro test, installed new seals in the valve and a new hose (old one had a 1991 mfg date printed on it) as the old one was very stiff. Total cost was $45. A new comparable extinguisher (Badger is out of business, bought up by Amerex) was $71 at discount, from the FX service shop, almost $90 retail.
I'll cycle the other flea market FX (Amerex 10 lb) thru the shop next year, and after that the other Badger (tall skinny 10 lb), which was properly opened and inspected in '05. I have one new First Alert 10 lb purchased from MSC's annual warehouse sale, it will be serviced last.
Don't forget your smoke alarm batteries. Did both of mine yesterday, along with the batteries in the Schlage electronic door locks of the shop and house, and the alarm clock back up battery. All 9v.
Charles
PCO6
Newmarket, Ontario
I keep 2 ten pounders just inside the main door to my garage. I also have a 4 pounder on a shelf over my bench and a few more next to my welders.
Vinci
I have a couple small Halon 1211 extinguishers and just picked up a 13# Ansul FE-36 from Craigslist for a song this weekend. I can't believe how insanely expensive those things are!
I spent some time today looking at "Cold Fire" extinguishers. They appear to be almost unbelievable in how well they work on AB fires. They claim to be user-serviceable too, which I like the idea of.
Has anyone on GJ used one or know anything practical about them?
marinusdees
Edgewood, Washington
Don't use a dry chem(powder) type on an engine fire if the engine is running. The air intake will **** the powder into the engine making the engine a throwaway unit. Use a Halon unit. Considerably more expensive but made for electrical (computer) fires and worth it.
PD
