teletekman
Random question for all those that use soldering irons, and stations.
Do you guys use different tips for the various bits of work that you do, and if so, what would you regards as your most commonly used tips?
If you have stations, what additional parts would you buy to keep as spares when replacement is necessary?
As I said in an earlier post, I'm buying a few bits and bobs, debating on buying a set of tips or individual ones, as well as a replacement heating element/holder/barrell, don't want to buy a bunch I'll never use! lol Thanks for your help in advance.![]()
It all depends on what type of job you are doing as to what size tip you will need. If you are working on circuit boards with mostly SMT components as small as 0603 or even 0402, you will benefit greatly from using smaller more precise conical tips. True they will not transfer the heat as quick but when you are using a fine gauge solder such as .015 or even .010, you don't need to apply large amounts of heat as your working area is not large to begin with. If this is just to be used around the house on normal everyday projects, (pieces of wire 18G & larger, standard through-hole components or even using your iron to melt plastic) yes the broader tips such as your spade or even larger chisel head tips will work great. Most irons will come wih some type of standard conical tip which my HAKO iron has and that I use quite a bit for working on automotive projects. And if you are buying solder from the local hardware store, most of the time you will probably not go any lower than about .030 which is pretty common around the home or garage so here is where the larger tips will come to play.
Here are a couple of links with different style tips that are pretty widely used from different manufactures...
http://www.arcade-electronics.com/Weller/PTseriesTips.jpg
http://img.alibaba.com/img/pb/911/739/276/276739911_572.jpg
