I just stumbled on this forum while researching garage lifts, and boy am I in heaven. I won't be getting much done in the near future as I am glued to the computer.
As to the topic, I recently repainted an old Lista cabinet that was the original baby blue with lots of painting and repainting of lettering/numbers etc. on the drawers.
I couldn't figure out what color I wanted to paint it. It seemed too big for the traditional red. In any case I tried several different combos and finally settled on the two tone one in the pics. I ended up using rattle spray cans:
Frame: Rust-Oleum Hammered - Brown
Drawers: Rust-Oleum Hammered - Dark Bronze
I was concerned about using the rattle cans on the large sides, as I have the spray equipment to do it "right". The problem was I couldn't get those colors or texture in regular cans. In any case, the sides are fine, and the drawers are excellent. I'm glad I never messed with the spray equipment.
The handles were somewhat scratched and not up to the new paint job.
I was going to put in the paper labels with the clear plastic cover strips. The problem was that the ones I had were never used, had been stored in a box, but still had a yellow cast and detracted from the cabinet. I ended up using electricians tape instead, and am very happy with the results. The tape is a little tricky installing. First cut a length a couple inches longer than the handle. Then pull the tape tight, hold it on edge, and with a slight sawing motion, slide the bottom edge into the lower slot. Once you get it fully into the slot, then you can stick the rest to the handle. That will cover a little more than the bottom half of the handle. Now, do the same to the top. It will overlap the bottom piece. I'm guessing that it is better to have the top overlap the bottom. On the first couple of handles, I trimmed the electricians tape overhanging the ends right away. The next day, the tape had shrunk slightly (it was stretched while pulling tight to install). So, I learned to wait a day before trimming.
The hardest part was finding some end caps that I was missing. This is the older style cabinet, and Lista and all of the distributors I called, don't have any more of that style. In any case, I found someone else with a cabinet he was selling that was missing so many end caps, that he sold me the remaining ones.
The best part of this story is what I am using for the drawer liner. I initially purchased some of the standard cheap drawer liner that is soft and foam like. I made due with it, but it was easy to gouge. Then I was finally able to pick up a roll of the ULTIMATE drawer liner from my brother.
So, what makes the ultimate drawer liner? Actually, my brother bought this rubber at an auction years ago from Aerojet corp.
This stuff is actually rocket booster liner. It's super expensive, or at least it was for the government. Fortunately, we got it cheap. This rubber was actually ground to an exact thickness. Note in the pic the numbers written on it. Those are all over the rubber and are thickness measurements to show that it meets specs.
That in no way makes it a better tool box liner, but it is interesting. But the density and texture DO make it a perfect liner.
