Let's see your vintage drill bit indices
fowldarr
Coastal Oregon
I was thinking about that, does anybody have a conversion chart for the closest fractional size to the older numbered system (what size is a '1' or a '7')
akalian
St. George Utah
Is this what you are looking for?
Socket Pounder
Santa Clarita
The numbered bits fill in between fractional bits. For when you need a drill bit just a hair smaller than, or larger than, **/**.
larry_g
oregon
The numbered and letter bit do not convert to fractional. The best chart I have come across is this one, http://media.guhring.com/documents/tech/Charts/CutTapDrill.pdf . From it you can find the hole size most likely to be made by a given drill bit, and the percentage of thread depth that you will end up with.
The one your looking for is this one, http://media.guhring.com/documents/tech/Charts/DecEquiv.pdf From that chart there are ~350 sizes under an inch.
lg
no neat sig line
WagonHo!
Albuquerque, New Mexico
General twist drill display case. I’ve been using a Kennedy machinist box for “all” my drill bits, hole saws etc and I really like that it keeps things organized even a place for bits that need to be replaced or sharpened. Don’t know if I’ll change over to the dispenor case it’s got the original glass that is just asking for to be bumped and broken. A couple of bit conversion charts from a 60’s machine shop in Albuquerque, they’re really clean so must have been in the office.
Burn1
Texas
Finally found a NOS set of Cleveland Drills for the stand.
Visey
NC
Here is a Huot index I just picked up. Sorry about the cobwebs...
jonshonda
Wisconsin
somebody sell me a cool drill index please. Looking for a nice older one that can lay down in a tool drawer.
454ragtop
Carver, MA
Found this Craftsman at an estate sale the other day, sadly the paint is flaking off badly, and taking the Craftsman logo with it.
Burn1
Texas
Does anyone know what brand of 29pcs standard drill bit set has a full profile shank for use in a drill index? All the box stores I have looked at have reduced shank dia on the larger bits.
Wish to find a new set that all bits fit properly up to the 1/2 bit in 29pcs set.
Your help is greatly appreciated.
Last I heard Norseman made top quality bits.
crguy
SW Washington
I just got this 1912 Patent Peerless drill index. Adjustable legs on the back panel, and keyholes for wall mounting (?). The Peerless name is also on the inside of the back panel (?).
What really confuses me about this is the way the sizes read from left to right, And right to left in the same row?
The only other picture I found of one of these was on Worthpoint, and the sizes all read in one direction on that one. It also had one less row, which may have been an option as each row (and the front & back panel) are all bolted together.
Any ideas on why the sizes read that way?
Oregon rock crusher
West of Salem
That is a very nice and unusual index crguy. I think that is the only vintage index I've seen that has more than one hole for each drill size, especially the easily broken smaller sizes. Pure speculation but putting the fractional sizes sideways like that let them use a much larger font that covered the grouped drill sizes and it sure is easy to read. Looks like a good and rare design feature. You've sure got some neat indexes and I think this one rates high on the desireable list. Ed.
h~moto
Northern Virginia
I can't answer your question as to why the sizes read the way they do, but I love the way the sizes are arranged. Each bit is 1/8" larger than the size in front of it. The system puts all 16ths in one row, two rows of 32nds and four rows of 64ths.
crguy
SW Washington
I actually acquired 2 drill indexes recently. This one had to be repainted. Made by the Morse Twist Drill & Mach. Co., it holds taper shank drills from 3/16" to 1".
I have a full set of taper shank drills in a wall mounted index that I made. Some of my drills step up in shank size before the holes in the index do, so I couldn't completely fill it up, but the pic will give you an idea.
Sizes are stamped in the nickel plated brass strips on top.
It took an impressive amount of patternmaker work for the castings on this. The top plate is a separate piece from the rest of the "X".
Anybody else seen one of these?
rshadd
Doylestown, PA
General Hardware Mfg. Co.
D
Davefr
OR
That's an impressive piece and a great restoration!!
454ragtop
Carver, MA
Really like that taper shank index crguy, as well as that other unique one you just posted. New Bedford is only about 15 miles from here, you'd think there would be more of them around, but I've never seen one.
D
Davefr
OR
A few new additions. Pretty scarce Raised Globe CTD, Morse and what I think is a homemade brass carousel.
Maui
Upstate NY
What methods have you guys used to successfully clean these metal drill bit indices? I’ve got several Cleveland Twist Drill indices that I have been wanting to clean up, but I’m not sure what the best approach would be, and I don’t want to damage the original finish on them. Would evaporust be a good candidate?
Maui
I just used a brass hand wire brush to clean up this one I picked up at an estate sale today. I blew out the holes for the bits with compressed air and wiped it off with brake cleaner. I hadn’t seen any interesting ones lately but I had to grab this one.
-Don7F2C0611-E15F-4114-A76A-8A75AFBDAB7C.jpg71CB8579-1684-4BB1-8A36-03F5130F51EB.jpgE94F9384-A9A3-48B8-B74B-ECA5A056FAB6.jpg
crguy
SW Washington
Nice! I like the decorative touches. I have one of those myself.
D
Davefr
OR
A 3pc Morse "select-a-matic" set. Interesting concept but I'm not sure it's all that efficient to quickly select a bit. I wonder if the intend of these was for carrying around in a portable tool box?
I spent some time with the Drill Doctor sharpening old bits and going through my spares and am just missing 4 bits from filling up my new index. Good rainy day project.
Wow, two indices in two weeks. Today was a number mate to my Cleveland Twist Drill fractional index. Found it at a little Berkeley estate sale this morning.
-DonC559CFD1-E827-46CC-9334-33E12A197732.jpgE2AEE8C2-A6D8-4BEC-BC2D-AD275CDCC2F8.jpg2727D59C-0477-48F7-A686-53BEB6F9A496.jpg
gearheadglen
North Jersey
Its been a while since I've posted. Wanted to post a couple I have not seen represented yet. First is a Montgomery Wards, the second pic are 2 Wells Brothers (which are super early and very rare). The last picture is a NOS Union Card index. I have a metric Standard Tool Co that I'll have to remember to get a picture of so I can post it.
D
Davefr
OR
Wow, those are really cool!!!
