Lets see your workbench
freudianfloyd
Nowhere
Ive posted my workbenches before, but they have changed quite a bit since then.
The back wall workbench before:
[/URL][/IMG]
And after some free racks from work...
[/URL][/IMG]
And the front work bench before....
[/URL][/IMG]
Since then I have picked up a new toolbox and was given some butcher block. It is still a work in progress, more pictures to come...
[/URL][/IMG]
RedF
Central Alberta
In progress.
Still needs the top fastened down. Debating putting screws down through the top, or buying a kreg jig and fastening from the bottom. Opinions?
Will be getting a bottom shelf, about 16" deep. I want to be able to sit at the bench on a shop stool with my knees underneath.
I need to find a vise.
Will angle brace the back and sides, if it needs it.
Carlos49
Nice looking welding table. I"m a newbe to welding and I need to build a well thought out welding table, I want to do it right the first time. Does anyone have plans for a welding table???
JeremyManning
Ontario, Canada
In progress.
Countersink screw hold and glue in dowel plugs work good.
bulletpruf
San Antonio
Went into the garage yesterday morning to work on a transmission rebuild for my Alfa Romeo; also planned to wire brush and clean up my new-to-me anvil as well as finish up a few Wilton bullet vises that I have been restoring.
Of course, none of that happened.
I was looking at all the spare dimensional wood in the corner and then lamenting the lack of workbench space when the lightbulb went off - what I really need (read: what I felt like doing) was a Portable Dirty Room (PDR - credit to GJ member BB767/Thomas for the name). PDR is something to bolt a bench grinder, belt sander, and vise to so you can wheel your project outside and not worry about making a mess in the garage.
This build was pretty cheap -- the wood is pretty nice, but it was salvaged from work (free). The casters were purchased for a rotisserie project but I ended up buying a complete rotisserie.
Anyway, it's pretty self explanatory, but here are the spec's - top work area is 24" x 44", and it sits 36" high. The top of the vise is right at 46" which is the same height as my elbows, so it should be a pretty good height for me. I'm 6'4" so it's rare to have a bench that has the right ergonomics for me.
The uprights are 4x4. The frame for the bottom shelf is 4x4 with 2x6's on top. The frame for the top shelf is 2x6 with 2x6's on top. It's quite sturdy.
I will bolt the vise down in a corner, but probably make it easy to remove. Same with the grinder. Will try one of Swag Off-Road's trick organizers to hang some grinders and other items from - http://www.swagoffroad.com/Work-Bench-Clutter-Catcher_p_46.html. And I'll figure out how to hang some clamps, etc from it.
Not bad for a few hours of work.
Daniel_DePetro
Sterling Heights, MI 48310
Not nearly as monterous, glamerous or flawless in execution as most benches in this thread, however it is stout and serves the purpose extremely well.
I built it in 2007 and it looks as good now as when I first built it, even though it has been in my fathers auto repair shop.
I built the frame out of scraps/drops from my place of employment at the time.
I inquired about building a bench out of a plate (it was a drop from a job years ago) they had which was sitting there since I started a couple years prior. I gave the list of the materials I needed (made with what I could find that they had in stock in the "drops" section) and they told me if I bought the top and used drops for the rest, I could just have everything else and use their shop & welder to assemble it. It was 1/4" thick wear resistant hardened steel plate, which they claimed was $800 for the full sheet, They charged me $165.82 out the door and I was happy as a clam.
I threw together a quick plan, gathered up the stock, measured everything, cut it all to spec, and welded it all up. which took me about 4 hours to complete.
The frame is all 2" x 2" x 1/8" angle and the legs are 1" x 1" x 1/8" square stock. The frame stands securely by itself as the top is not part of the structure.
The bench measures 44"W x 24"D x 35"H (at the table surface; this was as large as I could make the top and have the side be parallel). Overall height is 38" as it has a 3" border around the back that comes partially up the sides to keep stray fluids, bolts, nuts, washers, springs, clips, parts, ... from being lost forever.
I do have another piece of angle that goes across the front on the bottom along with a 3/16" piece of mild steel plate that I use as a bottom shelf when/if I do not have a V8 shortblock or transmission assembly hiding under the bench.
Here is the basic assembly from material pile to completed work bench...
Materials (minus top):
One side completed:
Both sides completed:
Laid down with the back attached (looking at it from the 'top'):
Standing upright:
Center brace added to top structure:
Angled front supports added for rigidity when the bottom shelf assembly is removed:
The "dirty" top installed:
Completed bench (before being cleaned up and wiped down with ATF to look slightly better; I also have another piece of angle that goes across the front on the bottom along with a 3/16" piece of mild steel plate that I use as a bottom shelf when/if I do not have a V8 shortblock or transmission assembly hiding under the bench.):
speed bump
Butte Montana
My basic workbench in the woodshop. Now that it is getting warm I will probably put some finish on the birch plywood top and paint the rest of it.
Fordriver6
Afton, VA
So I posted this earlier tonight in another workbench thread before I found this one. It's a direct quote from the other thread.
So I have four workbenches in my shop. At the moment, two are in pretty good shape and two need cleaned off. That's par for the course around here.
First one has my frankenstein grinder on one side and a Wilton C1 and cheapo Craftsman drill press on the other. Just got the pegboard relatively organized this past week.
Second one I got from my uncle's estate a couple years back. Cordless tools on top, mainly automotive electrical stuff hung on its pegboard. It's currently a catch all until I organize some more.
Third one used to be a shelf and had a shelf on top of it. One day decided to tear the top shelf out and make another bench out of it. Just mounted my swivel jaw Parker 273 to it yesterday.
Last one is one me and my dad built years ago. It currently home to my fastener organizers, thread checkers, and plenty of hardware i havent organized yet (as well as a Stihl trimmer that needs the carb gone thru).
Sent from my XT1080 using Tapatalk
cheechi
Triad, NC
Right after I hung all the begboard and filled it up. The cleanest it's been in a while.
Russ G
Interlake area, Manitoba
There are some great looking benches here. This one was built by my Uncle many years ago and passed on to me. I was going to make and add some drawers for the middle but thought twice about it. I want to leave it just as he built it. He serviced and repaired a lot of small engines and yard equipment on this bench. I wish I could have spent more time with him and also wish that he could have hung on long enough to see this in my finished garage.
Lee Celtic
Llanberis, North Wales UK
Ok so I've trawled through all 139 pages checking out some awesome looking work benches.. and it seems to me you all like one with a story.. so here goes mine.. and it's a doozy.. :) .
My late Father in law as a teenager was adopted by a farmer in Suffolk on the East coast of England. After the outbreak of World war 2 he was part of the effort to feed Britain and as such was exempt from serving in the services (though he was actually too young when war actually was declared) in 1944 the US Airforce took over an Airfield built by the RAF and the 34th Bomb Group moved in. For the remainder of the war he was one of the few civilians allowed on the base as they were still farming the land between the runways.
You can clearly see the field walls inside the three runways..
At the end of the war things were wound down and eventually the US Air force left the site.. My Father in Law had been given the heads up that they were leaving and invited to "Help Himself" to anything left behind.. he went there with a few friends and a good few trailers towed behind tractors and horses and loaded up everything he could the day they left.
One of the things he took was a food warming unit from the mess. He took it to the farm where it was stored in a barn until he moved to the other side of the country to Marry my Wife's mother around 1956. Amazingly he brought the food warmer with him and installed it in the lean to workshop of his own farm.. Unfortunately he died 20 years ago but on his death I was asked if there was anything of his I wanted to keep.. The only thing that popped into my head was the food warmer.. He'd fitted a Record No.25 vise to the top many years ago and it was still fitted and after using a front loader to get the thing on a trailer me and 6 friends struggled to slide it on two trolly jacks into my Garage.. and there it still sits today.
https://scontent-lhr3-1.**.fbcdn.net/v/t1.0-9/13537623_10210467760397123_2523753166029738152_n.jpg?oh=aa92cafd306b2fd62ca0195705bc7a6f&oe=58039C47
Weight is very very heavy, size is about 7 feet long 36 inches high and 30 inches deep.. it was like pushing a car with four flats.. top is 1/4 inch steel rolled front and back as people would have used it from both sides and the base is all 1/4 flat and box bolted and welded together..The sliding doors were missing so I've made a few from ply and steel but the plan is to get the whole thing back to bare metal and clean her up.. it's really handy being able to weld blocks to the top for welding jigs then just grind them off afterwards. The vise was mounted a little too far in and needs to be re-positioned a little more to the edge but apart from that it works great and will hold the weight of a V8 and trans without any flex or bowing. It even still has the gas burners underneath that kept the meals inside warm.. As said a full resto of the bench is to come along with the vise. and yes there will be photos. :)
J Persons
Louisiana
Do you know the name of the field? I was stationed at RAF Bentwaters/Woodbridge, (Suffolk County)in the early '80's. I enjoyed my time there.
32krazy!
i picked these stainless steel cabinets up from a dentists office for 500. 3/4" plywood tops finish it off. built some wall cabinets to store leftover stuff and finally installed my maxjax. no more laying on the floor!
Shiftless
East Bay SFO
Fine workbench you have there!
IMHO, Your uncle's bench would look even better with a vintage vise bolted on. :thumbup:
firemark2643
Charlotte, NC
My New Benches
Wanted to share my recently completed work bench project with the Journal.
The frames are 2x10, legs 4x4, 3/4" plywood tops with Armstrong commercial grade flooring and 3 coats of clear poly on top to seal everything. Corner pattern was fun to lay out, wanted the two benches to match up all the way to the center. Brackets now have 2x4s for shelving and metal pegboard coming to fill out one of the backs. I'll add the finished product soon.
Finky198
North East
New work bench in progress the last few days still moving stuff around added some outlets, air tool holder, over head box, next is air and More lighting...an under shelf and another shelf to the ceiling.
LS6 Tommy
Northern NJ
Looks good. I wish I had room for a separate setup like that with a vise or two and some clamps. I usually use the entire work space on my benchtop and those hammers and bars hanging in front would drive me nuts trying to work.
Tommy
Finky198
North East
Tommy
I don't really do to much work at the bench its more about tool organization. Ill do small projects, electrical, testing, ect at the bench. The stuff on the front is more for ease of access as I'm in the middle of a double deep bay. I usually go to the vehicle or one of our large empty work tables as per project...
Space is always the biggest issue.... But not as bad since the addition.
BSAschields
East Coast
So I had this cabinet that got bent out of shape when I stupidly got p*ssed off at my son for not helping me unload it off of the roof rack on my Jeep and I drove under my carport. It didnt fit!! :eek: Not only did it damage the cabinet but tore off my roof rack too ...... I was not happy. That was a few years ago and I never threw away the cabinet. Just as I was about to do so last week I suddenly got inspired...........
Its metal ..... Its big ....... Ive got a saw ....... Smell the smoke yet?
Nice addition to my bench. Continuing with the free theme since the cabinet was given to me . The Vise was not free.... But I like it
As you can see I finally added the drawers too. Need to make them work smother though.....
drivesitfar
BSA: just curious what kind of tool you used to cut up that metal cabinet? i've got a few old shelving units that i could use the metal for drawer liners in some old file cabinets and was thinking about just using one of my many Wiss tin snips. i don't mind a little smoke if there might be a better way. do tell?
ALL: i tend to like big, heavy, steel things and benches just fit right in so the last few years i've picked up a couple of these old Army/Navy/Boeing steel benches that might weigh close to 300 pounds. it has 3 drawers and i liked the Army green, but the grey white wash had to go. i'm not sure if there is an easier method, but 4 hours of using both my Milwaukee 7.5 inch grinders with wire cups on them did the job. then i put on a few coats of BLO (boiled linseed oil) to keep it from rusting. i'm also planning on building a cabinet for the space to the right of the 3 drawers where i have some old goverment issued bins to put in there or i might use my bigger Lyon bins.
with a big vise on top of it i'm pretty certain it won't move. now if i could only keep it from just piling up with STUFF because i have FSD (Flat Surface Disease) and there isn't a pill to cure that that i'm aware of.
sberry
Brethren, Michigan
I like it out on the floor for fab, along a wall is ok for auto.
bulletpruf
San Antonio
Drives -
Cutoff wheel or sawzall would be fine for cutting the metal up.
4 hours is a lot of time spent stripping. Try Aircraft Stripper - either liquid (get a gallon) or aerosol. Check TimeWarp or HD FLX's threads in the fab section for pictures; they both use it.
Scott
