BackTracker
R.I.P. - Brad54, 2010.
Died of a massive coronary over the completely insignificant issue of what screwdriver someone else on the internet bought with their own money.
L O L
Don't feed the dragon, by American. Look at the Proto 19 pc set, I am waiting for MSC to send me a 35% offer and I plan on snagging them for just over a $100.
Where is your Wiha microfinish???
Here's a sampling of the different handles out there, they're all P2 size![]()
I bought one of those to try out. Does the handle eventually stop flaking off in your hand? I'm not impressed so far.
What is the maker of the one that is second from the left on the top row?
I already have my eyes on the Stahlwille version and the new Witte Protop II Plus screwdrivers with the microfiber coated handles.
Monte,
What brand is that orange plastic handled driver in the upper right corner of your photo?
I really like Klein, IMPO their insulated line is the best in the business.
Not anymore. Kleins have gotten much worse and the first camout will ruin the tips. They're much softer then they used to be.
I dumped all my Kleins for PB Swiss and am much happier.
Monte,
Shame no one has mentioned these:
Indispensable to Elroy. You would be well advised to add a set to your screw driver selection
So what is the best "budget" higher end solution. I would love to supplement my standard CMAN set with a set of higher end drivers.
For "budget" high end I'd recommend Williams black handles. (Snap On relabeled).
I guess someone had issues with them but the ones I just got are perfect.
running screws into wood really test a driver, particularly a Phillips driver.
KEH
You all are looking at the drivers from the viewpoint of mechanical or electrical work. I do some woodworking and running screws into wood really test a driver, particularly a Phillips driver. KEH
That's why we use only Robertson screws and drivers for woodworking in Canada.![]()
Robertson screwdrivers don't cam out unless really worn.
I've had trouble with them in stainless steel deck screws. The screws are a pretty soft 300 series stainless and if you get careless with that square bit at all it will cam and then round right out. Still better than a Phillips, but aggravating nevertheless.yeah Robertson tips are much better then the phillips tip as they really don't cam out easily unless the fastener is **** or the tip is worn out.
