MatBirch
My new home has an old carport that has probably been in use for more than 40 years. Over time, there are significant hollows in the parking areas, as you are required to turn sharply to get in from an alley. They are deep enough that the car sit at a pretty good angle, and the drivers door swings out violently if your not careful. There are also steel post holding the structure up. The other day, I was getting into my wife’s car, and not being used to it, the door swung out and smashed my finger between the door and the post. Pissed me off enough to find a solution!
The dirt has separated over the years to the point that there is gravel, and there is powder. (I’m also worried that the powder will turn into mud once winter sets in). There’s no good mix of materials. Anyway, I know that just grabbing shovels, rakes, and implements of destruction will only give short term results. What can I mix in to stabilize it better? I’ve seen people just spread quickcrete mix onto pathways to firm them up. Do I need to excavate it further down? I’ve seen enough failures trying to fill potholes on a dirt road in my time.
Replacing it all isn’t in the cards right now. For one, I Hope tear it all down and replace it with a garage someday in the next year or two.
Thanks for the help!
