Leveling a Water Heater
dougw181
Belgrade, MT
I recently had to replace our gas water heater since the bottom rusted out
and it flooded our garage. I installed an overflow pan and plumbed it outside,
and replaced the rigid water supply lines with flexible lines. The water heater
sits on a wooden platform about 18" above the garage floor. I can not get
the new unit to sit level. The platform is level, the overflow pan sits level,
but the water heater leans about 10 degrees to one side. I am thinking that
one of the feet on the unit is shorter than the other two. Would it be OK to
shim the low side with plastic shims? I really do not remove the unit and
return it for another one since it works fine and does not leak. Has anyone
else experienced this problem. Any advise would be greatly appreciated.
Doug
naturalgas
Metrowest Ma.
Put a black iron ****** under the low spot. Or a stone. There won't be any heat there ,you just want something strong. Each gallon of water in the tank weighs 8 pounds.it is done all the time in dirt cellars .
Muzzy
Northeast PA
Is there any height adjustment on the feet?
Seems awfully odd that it leans that far off on a flat surface. I don't know if earthquake straps are required in your area, but if I were shimming it, I would make sure that its strapped to a wall before filling it with water.
BD1
north side
No problem leveling, you can use some sheet metal pieces to level, or even large flat washers .
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Make a square or round frame and pour it full of self leveling compound and sit the water heater on top of that. It only has to be about an inch or so thick.
joelzip
I am a master plumber for a living and shim every water heater I install in basements with composite shims.
sixty4
CT
I just use a few nailing plates myself. Flatten the ears of course.
D
dougw181
Belgrade, MT
Thank you for all of your suggestions. I am going to use composite shims
to level it, and then add the strap kit once I have it leveled. Once again,
Thank you for your advise.
Doug
tipsy
Speedwell, Tennessee
If the platform is level and the pan is level then the big question is why isn't the water heater level? There has to be something wrong or dented or junk stuck to the bottom to be throwing it off by ten degrees. Are you flexible lines too stiff? And holding it up crooked? Did you fill it with water yet? If no, then it's possible that when you add the weight of the water to it, it will level out. You need to do some exploring to find out why it's not level when the platform and pan are. Try disconnecting the supply lines and see if it sits level then.
rlitman
Long Island
You're wondering the same thing as me. I wouldn't fill it with water if it sat that far off level. Adding shims to correct for a unlevel floor, or maybe 1/2" off level at the top, ok. But shimming 10 degrees?!?
Did this thing fall off a truck before you got it?
