scoob8000
I've been noticing as my garage door goes up the bottom right (looking from inside) begins to bind with the track when it's up almost the whole way.
The only thing I can figure is the spring on the RH side has slightly more tension on it, causing the door to **** a bit as it goes up.
If that's the case, is there any way I can safely release a tiny bit of tension on that side to see?
Good luck man.
