tsmith912003
- Joined
- Aug 13, 2014
- Messages
- 1
I have an LG mini split system heat pump with one unit in the living room and one in the bedroom. Has been installed now for 2 years with no problems. Now the living room unit will not cool the room adequately if turned on by itself. But when I turn on the bedroom unit, the living room unit starts cooling as it should. I had a service tech check it out and freon level was good and pressures were spot on. Even when I put the unit in Jet Cool mode, it only blows room temp air until I turn on the other unit then it begins blowing cold air. Any suggestions or ideas would be appreciated. The tech left scratching his head on this! Thanks for any replies.
