License plate screws...
spy604
nothing special about a license plate screw, just a 1/4"-20 self tapping screw, about 3/4" long. See if your local HW store has some in stainless.
Badger 13
Northern Idaho
Since some people still "steal" license plates, I have replaced the "traditional" type head screws with either torx, or allen heads. The crooks will usually go to an "easy" removal. I find the stainless ones at ACE hardware.
A1an
Tampa, FL
I went to Lowes and purchased stainless bolts. I believe those security license plate screws you find at Advanced Auto are also stainless. I had a set on a prior vehicle and they never rusted.
ddawg16
S. California
Very true.....by nature, crooks are very lazy.
While your at it....remove that stupid frame that car dealers put on. When I buy a new car, I usually tell them to remove it before I drive it off the lot.
QBall68
For those that have to display tags on the front of your vehicles, do you know what's behind the plastic bumper cover on cars that don't have a bracket? My wife's got a '08 Toyota Highlander & wants to put a tag on the front for her favorite college team, but there's just 2 dimples for the screws...and I haven't been able to bring myself to just run 2 screws into it yet, not knowing what's behind it & how well it will hold?
spy604
usually the bumper holes are made to hold the plate bracket, which is either held on with blind rivets (pop rivets) or screws. If you hold a plate up to those bumper holes, I bet the holes wont line up.
QBall68
No, actually the dimples do line up with the plate holes - and Toyota does not make a front license plate bracket for the late model Highlanders (cost savings?)
Perhaps I should just drill a small pilot hole to see what's back there...or convince the wife that *everyone* knows what team she likes! :)
rebelram
AL
I usually try to put 4 fasteners in my car tags. I also alternate them, 2 phillips screws and 2 bolts. My logic is, what thief is going to be carrying both a philips screwdriver and a ratchet or wrench? I like the allen screw idea as well. Only way I see to defeat that is if a thief is extremely skilled and quick with a set of vise grips.
paranoid56
San Diego, Ca
those dimples are just 1/2" thick plastic, you use normal screws just screwed into the plastic. has held fine on all my cars.
A1an
Tampa, FL
Yep...self tapping screws work fine. That is what most manufacturers use to secure the front plate holder/frame to the bumper.
Before you go doing that you may want to consider a different way to display it up front. When/if you go to sell that car it is nice to have a bumper w/o holes in the front bumper cover.
QBall68
A1an, thanks - any suggestions or ideas for alternative displays? My concern is exactly what you described, not wanting to sell it with holes in the front bumper cover...
gahrajmahal
Cincinnati, Ohio
On my wifes Corolla there was nothing behind the dimples. The Toyota bracket just uses #12 sheet metal screws. Threads into the 1/16 thick bumper cover. Chintzy but has held for a year.
Greatbear
Columbia/Fulton, MD
I picked up sets of stainless "security" screws for license plates from either Advance or Auto Zone. They have the 1/4" self tapping as well as the M5 metric machine screw versions used on some imports. They are allen head with a center pin, and come with a matching key wrench to install and remove. I put these on my fleet of cars and trucks. I don't recall the brand of the screws, but they can be found among all the license plate frames and other bling.
nehog
Jaffrey, NH
My Saab came from the factory with Torx screws for the plates. No rust on them, but then the car shows 6,700 miles (for a 1990) so it's not seen a lot of rain either.
Statistically you are much more likely to loose a plate than have it stolen, so any screw should have good holding power. And face it, if someone wants to steal your plates, they will get them, probably sacrificing your bumper, plate mount, trim and whatever else they have to, in order to get them. For this reason I think if you have a metal surface, welding them on is the most secure way to go. Don't forget to fill in the holes when welding. :lol_hitti
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I have those also, but it is best to get an extra wrench or two. I had to put a new sticker on my plate and couldn't find the wrench for them. I finally found it after about an hour of looking. I had tossed it in the drawer with my other Allen wrenches and it got shifted around and buried. :lol_hitti
I did a search to find a pic of the screws and this site popped up http://www.keyedlok.com/tamperproofscrews/keyed-lok3.html If someone was really worried, they have a multitude of different styles :eek:
NUTTSGT
Northern Central Ohio
http://www.toyotanation.com/forum/showthread.php?t=381021
Go to post #15. Apparently they do make them. :beer:
NUTTSGT
I have to put the new expiration sticker on the wife's Explorer and my truck. I've been wanting to get some SS screw for the plates. Now I know they are commonly available and no need to search around for them.
Another big thanks to GJ.
Greatbear
Columbia/Fulton, MD
I keep the wrench that comes with the kit in the console or glove box in the vehicle. I have other tamperproof drivers I can use if needed. In fact, I have to go through the motions when it stops raining to put the new expiration sticker on. I like to remove the previous stickers instead of stacking them on.
4BT
stainless nylock nuts and matching bolts keep my plate on the truck.....it's easier to remove the bumper :lol:
Alchymist
Central PA
And any thief worth his salt will have picked up a set so he has the wrench too! :bounce:
