rattle_snake
I prepped my new building for a the installation of a 2 post lift. I now have the opportunity to use a friends lift that he just acquired, for at least a few years until he builds his own shop.
The lift is a Atlas BP 8000. I was going to get a Bendpak XPR-10S. The Atlas is not enough, on paper, to lift my truck, so I still plan to purchase a 10k lift down the road.
My slab is 4" 3k psi, except for where the lift was originally going to be placed. I increased depth to 6" in a 4' x 6' area around where each post would go.
I am hesitant to install the Atlas in the original target location, as the hole patterns are different. I don't think I should drill additional holes for the bendpak in close proximity to the existing ones from the Atlas.
OR maybe I can, what do you think?
How close can I drill next to an empty/abandoned hole?
I understand that the baseplates themselves have multiple anchors close to one another, and can de-rate some anchors specifications.
Option B is placing the Atlas within, but near the edge of the 6" deep area. That would give me about 15" between the rows of anchors (columns centers 27" apart)
WWGJD?
Extended rambling:
Also to note is that the Bendpak in wide configuration is 21" wider than the Atlas. This leaves the outer anchors (the REALLY important ones) at least 10" away from any existing holes, even if installed in-line with one another .
WWGJD?
Extended rambling:
