Lift columns over XPS foam
Crawlin
NC
I will be getting my shop slab ready for concrete soon. It will have 2 XPS for radiant heating. I will be installing a 4 post lift and leaving the tubing out of the lift column area. Should the XPS be removed as well or can the columns sit on that? Using 25 PSI green board from Lowes. Also going to have a free standing steel mezzanine sitting on the slab with 6 columns bolted down. Wondering the same thing here. On my last shop I removed the foam under my lift columns leaving it thicker but think its better to have more uniform base. Just making sure the foam can support the lift and mezzanine.
C
Crawlin
NC
It is just a 4 post. 4" is all that is normally required.
HELLSUNICORN
I would not leave the foam out. When I did my 2 post I left the foam in but made that section of the concrete thicker and added remesh. I don't know if you need to worry about that with a 4 post. I can tell you to take detailed photos and measurements of the tubing before you pour the concrete. I did not do that and when it came to drilling the holes it was way harder than it needed to be.
ericm
Southern Oregon
Don't four post lifts have four large flat feet? Much larger than car tires' contact patches? Even with the weight of lift+car I bet the PSI on the concrete under the lift feet is less it is than under a car's tires.
Also the slab is going to spread out the load on the foam. Not perfectly evenly because it will flex some, but it'll still be over a wide area.
C
Crawlin
NC
Yes these are my thoughts as well. Was planning on leaving the foam, just thought I would get some opinions.
Farmall450
Marengo, Illinois
What he said ^
joe--h
25PSI = 3,600 pounds per square foot. What are you planning to lift? Will your hoist lift 7 tons? My backhoe weighs 7 tons but I don't think I'd want to be under it 6' in the air.
Joe H
66cj225
NH
Do the math for the worst case- driving on and off. Add a crack or two just for good measure. The situation is not much different than how long does the pond mud have to dry before you can put a machine on it....
C
Crawlin
NC
Joe H
Yes I am buying a 14k lb rotary lift. Some ton trucks with utility beds are around 13K. I would have no problem standing under that if the lift was rated for enough.
