tc-cad
Hello All
I have an idea and would like to get a discussion started. I like the design of the Scissor type lifts on the market. The mechanics of the lifts seem to be a pretty simple and similar design. The expensive part of the lifts to me seems to be the Hydraulic pump and cylinders and related hose/tubing. What if a design was done using the same basic principle but for power you could use an Electric Winch. A winch can be purchase at almost any weight capacity you can think of. I have seen pricing for winches any where from $300 -$600. In a production garage I can see where this would be a very slow lift operation but in a residential garage I think home owners can live with a little longer time frame to lift their vehicle.
Of course people will say that the cable can snap. True, however some lifts already use cables in their design.
I know some lifts use aircraft cable tied into a hydraulic cylinder for power.
Can any lift owners chip in and tell us what size (diameter) the cable is for their various style lifts they may have that use aircraft cable?
Another idea I have is to use the winch to drive a worm gear to raise and lower the scissor type lift. But now you are incurring the cost of a worm gear, possible but could be costly. The worm gear would act as a saftey lock at any level, which is a good feature.
Thanks
I hope to get a lot of discussion on this topic?
Any engineers out there interested in teaming up to build such a project?
TC-CAD
Thanks
TC-CAD
