LSVLance
I just wanted to make a post and let everyone know how much I learned from this site while researching my lift purchase and also to show off the install just a bit. I searched high and low on here and read a bunch of install stories before finally making my mind up. You all helped tremendously.
I ended up purchasing a Atlas OH-10X EXTRA WIDE EXTRA TALL two post lift from Greg Smith Equipment and I can't say enough positive things about this lift and Greg Smith Equipment. The lift is built like a brick shiat house and way exceeds my expectations and the price and service from the Greg Smith boys was great as well.
I had the lift shipped to my office because I had a forklift there. Once it was delivered, I set it on my car trailer and used the forklift to separate the pieces and lay them all down on the trailer to make it easier to unload at home.
The actual install took me about a day and a half, mostly by myself but I did have help unloading the pieces and standing them up and then walking the top piece up two ladders and getting it all bolted together. Having done one now, I could do one much faster the next time around. Basically I'd get the electrical hooked up as soon as possible and the hydraulic lines ran as soon as possible as well, using the motor to lift and lower the carriages instead of ratchet straps and brute strength would have made things go much easier, smoother and quicker.
But all in all it wasn't too bad. I did hit rebar in two of the holes drilled into the floor and this set me back a couple of days until I got the correct rebar cutter drill bit. Be prepared to spend some cash you wouldn't expect to spend on a drill bit if this happens to you during your install...
Once I got all of the holes drilled, the columns plumb and square, and the anchor wedges all tightened down good, I took my 6,720 pound truck for a ride...
It raised the truck with no problem and is VERY sturdy. All of the different sized peg adapters that come with the lift are very handy for getting the truck set securely and level on the arms. It just barely moves when pushing the truck around once on the lift. I feel very comfortable working under the truck on this lift.
I'm right at 6 feet tall...and I can stand under the arms of the lift when fully raised...without banging my head on them. Proof
Anyway, thanks to everyone here that has posted about their lift purchases...hopefully this post will help somone else out down the road that is looking for a big two post lift for their garage and needs some reassuring on their purchase.
Thanks,
Lance
Thanks,
Lance
