Lift install screws up a hole
acidice333
Drilled some holes and I screwed up one hole. Its offset so only 3/4 of the anchor is showing.
What do I use to elongate the hole in the steel plate?
coljar
Belpre, Ohio
Die grinder would be the choice tool for me too. I drilled the holes for my anchors with the lift setting in position. Was this an option?
A
acidice333
Thanks for the tips. I'll try the die grinder with bur.
Sadly it wasnt an option. the holes in the plates are 7/8 give or take and the anchors are 1". I do have a 7/8 bit masonary bit but it would most likely catch on the plate
A
acidice333
I did drill pilot holes with a 3/8 bit I think it was.. some of the anchor bolts are a bit tight so I will need to make the holes a bit bigger. but yeah its just one that is only showing 3/4 of the anchor thank gawd its on the inside so not that big of a tension on it.
pattenp
Virginia - USA
Okay?? What am I missing? A 1" anchor and a 7/8" hole.
mrobins297aaa
south east michigan
yeah really, why are you using 1" anchors with a 7/8" hole.
usually those lifts if they have a 7/8" hole they'll have a 3/4" anchor so you drill right thru the base plate.........eliminates all those mis alignment problems.
A
acidice333
Nope. Its the NAT C7000. Anchors require a 1" hole, the plate holes are roughly 7/8" so I cant quite use the plate as a template to get perfect 1" holes.
cunninglinguist
Vancouver
The Maxjax I installed needed 7/8 holes in the concrete and the lift had 7/8 holes on the base. I just used holes one the base of the lift as a guide with a 7/8 bit.
Maybe use 7/8 hole as a pilot hole through the base and then redrill with 1 inch?
edit: I re read your post again and your holes are only roughly 7/8 and they catch the bit so not feasible.
toyota mike
NY
do what i did.if a hole gets too big . go to home depo and get super strong poxy .it comes in a caulk tube for 20 bucks fill the hole and put in threaded rod. when dry large washer and nut. super strong.
