omowright
Which is of more concern, lift or jackstand failures? Are there any stastistics?
I leave the jack under the truck even once I get it up on the stands. I let it down until the weight is on the stands and then give the jack a pump or two until it just gets weighted then leave it there. If I'm taking a tire off I throw it under the edge of the truck too. You can't be too safe or careful imo...
This is exactly what I do too.
Yup.
Most of those jack/life pictures look like a side load was applied/wheels not blocked and the vehicle rolled off.![]()
I always a secondary stand in place,,block of wood or floor jack ...I use 7 ton Napa stands and the warning label clearly states not to go under vehicle when stands in use.
My friends steel CTire steel ramps collapsed under the weight of his 2 wd f150....always have a secondary
And the purpose of putting a stand under a vehicle would be...
Lawyers, Gotta love their lack of logic...
My blocks of wood are looking better and better!
Ramp stands are my current favorite for things where the wheels aren't coming off. I have 2 ramps made from an 8X8 and that gets the most use for oils changes and routine "I need more space to work top and bottom" jobs.
Useless for brake jobs however...
One nice thing about wood ramps is a slight slope doesn't bother them much, but do block the wheels...
Having said that, if you buy steel manufactured ramps, get good ones. There are some real crappy ones out there... (Same for floor jacks and jack stands for that matter, and no you wont get my under a jack stand with a cast iron post... Most Jack stand and floor jack failures can be traced to using them on a slope...
Mike pics? These are solid wood? or Hollow?
Solid wood. Here you go.
That's quite brilliant actually... Way safer than the tin can ramps HF sells.
Yep, Giant "plywood" ramps!
