Injected65
I recently bought a used Forward 7000# 2-post lift at an auction. The lift is now mounted in place and I need to get it up and running. I've left several messages with a couple of different electricians here in town and apparently my money is no good. I've decided to see if I can get some guidance here to do the job myself. I'm confident in my 110V wiring abilities and most 220V items (wired my welder and compressor wit no problems) but this lift has some wiring I haven't seen before.
I have a spare 20A breaker in the panel. I'll run the wiring over to a disconnect next to the lift. The pump motor did not come with a momentary switch but I have one here on hand. The motor has 4 wires coming out of it. T1 and T8 are twisted together. T4 and T5 are twisted together. I'm assuming that the momentary switch will be placed in one of the pairs of wires and then the other side of the switch and the other pair will go to the two legs coming from the breaker. I'm looking for some confirmation that I am on the right path (or if I am out in left field).
Thanks in advance,
Chris
Motor Data Tag - http://www.candbmotorsports.com/chris/P1000197.JPG
Wiring - http://www.candbmotorsports.com/chris/P1000198.JPG
Thanks in advance,
Chris
