Lift power shutoff switch and overload protection
cccoltsicehockey
Charlotte, NC
Getting ready to have my lift installed next week. The installers are bringing it with them as I had no way to unload it at my house. I am doing the electrical work for it though. I have read on here a few times about having a motor overload protection and a manual shutoff switch. The lift is a Bendpak 10APX but the motor documentation on the site just says single phase 220v. I had a 10awg 30amp circuit pulled for it since the documentation states it needs at least 25amp circuit but the Bendpak rep said they prefer it on a 30amp so that is what I did.
Would these both be sufficient?
C
cccoltsicehockey
Charlotte, NC
need to know the motor HP rating. unfortunately, bendpak's documentation is poor and they do not list the motor HP rating anywhere.
any way you can ask them to take a pic of the motor nameplate and send it to you?
Called and left a message. I imagine it is most likely a 2hp as that seems to be what they use most of the time. I guess I could order the 2hp and the 3hp since coming from Amazon an the return would be easy just in case. This would only matter for the overload protection though correct? I can order any 30amp switch regardless of the motor size?
I was even considering this switch since it would be more obvious in an emergency to someone other than me.
mm08822
Use a knife blade style disconnect with a hp rating stated on the label.
You don't want to be depending on spring loaded contacts to release vs risk putting a vehicle through the roof.
dave*99
Coastal NJ
I thought one of the reasons for adding a shut off was if the existing switch fails on. In which case you'd want a fast way to shut it down.
Exactly. My disconnect switch is very close to the push button on the lift pump. Quick and easy.
I have seen the push buttons fail.
The safety bar will stop my lift but I’d prefer a quick was to stop it myself.
mm08822
For speed, either use the lever arm blade disconnect or an ac disconnect with the lift cover removed. I would still pick the lever arm disco.
Norcal
Have you priced safety switches? I prefer them also but the are not cheap.
dave*99
Coastal NJ
However you choose your disconnect, consider that it can also be a kill switch. A disconnect is a convenient way to locally remove power so you can safely service a device.
A kill switch should be close to the operators position so it can be activated without moving much. I mounted mine right on the lift post. I can reach the power push button with one hand and flip the disconnect with the other.
C
cccoltsicehockey
Charlotte, NC
Interesting that the guess is 2-3hp motor but the rep wants 30a disconnect. Let us know how it goes.
It is really weird what BendPak requests for power based on the actual motor they send. The lift was installed and I hooked the power up with no protection so that they could prime the pump.
Here are the specs on the motor itself. Which really means a 20amp circuit should be fine.
However, right next to that information is this. Which to me makes absolutely no sense.
I ended up sticking with this style switch instead of the blade switch. The blade enclosure was just much larger.
It also states right on it that it is meant to be a motor disconnect and the spec motors it is good for covers the motor size on the lift.
I did go with a different enclosure for the switch with is more obvious and easier to operate quickly in the need of it to be a safety while still being smaller than the blade style switch I was looking at.
I placed it right next to the lift motor so you can operate it very quickly if it is needed.
