The only reason they are doing that is speed and to utilize their lifts for other work. In many cases they could rotate one side with a single jack under the front lift point, then roll it off to the other side and do the same. But if one person is doing each side all four corners need to come off the ground.
I use 2 jacks at home, but usually one on each side to lift the axle without resorting to leaning the car excessively to get one side onto a jackstand so I can roll the jack around to the other side. It's also a nuisance to keep wheeling the jack back and forth, I just keep one jack on each side of the bay I work in. That's more than enough. I never lift 4 corners off the ground for a tire rotation, that's unnecessary.
*edit* I don't rotate from left to right, only front to back. I don't see any value it rotating across sides (and I accept that someone on the interwebs will disagree) and most of my tires are directional anyway. If you wanted to rotate across sides, then getting all four corners off the ground is a bit easier. My preference there would be to have 4 jackstands not 4 jacks.
