Lifting plate for our track hoe
Jbullfrog
Avoca, Iowa
We have a 5 ton excavator, I wanted to build a plate to fit the quick-tach that I could use as a mount for attachments like a lifting clevis. I plan on buildning a mount for a 42" garden tractor blade for grading projects.
I had the welding shop cut the 1/2" side plates on the plasma table and weld them and the base together. I drilled the 2" tube and attached it along with cutting and drilling the 2-3/4" cylinder rod for the pins. They are longer as I cut them to the same length as my regular bucket pins so I can use them for other things if needed.
ChrisH20
We used an old backfill blade of a mini excavator for a blade mutch better built than a tractor blade.
