Innovate1
Not a garage question but hoping I can get some advice given the experience of the people here... Trying to help a friend with a house built in 1931. Single story. The ceiling in one of the bedrooms is sagging and has a crack perpendicular to the ceiling joists. They were thinking the roof was leaking and causing the issue but no signs of water below or in the attic. I went into the attic thinking the framing might be sagging but it isn't. The ceiling has pulled away from the joists by about 1-2 inches. I could see some nails that were bright - looked like fairly recent nails but I don't think anything has been done to the ceiling in many years - I will confirm that. None of the other areas have any obvious ceiling issues.
I advised them not to sleep there as the ceiling might collapse and some simple bracing was put in. Think the ceiling fan was helping hold it up. :O
The ceiling isn't breaking in other areas so my thought was to put some heavy plywood and/or a frame similar to a floor under the ceiling with a number of jacks and slowly push the ceiling up to the joists. Then screw it to the joists - thinking construction screws driven slightly below the surface so they can be hidden. Not sure exactly what the ceiling material is. I didn't see any lath from the attic. They called it stucco but that may just be the surface coating - I have a fair amount of construction experience but don't know much about construction methods that old.
They main issue I see with trying to push the ceiling back up is the resistance from the existing nails and cracking from uneven pressure when lifting. It seems like lifting would be a lot less of a job than tearing it out and replacing with drywall. One issue is locating the framing through the ceiling - I doubt stud sensors will work but drilling a few holes beside the joists from above would give their location.
Any suggestions on how to do this? What's the chance that lifting the ceiling will work? Seems like a reasonable plan to me but their "very good" handyman didn't want to tackle it. I told them to give him my number to talk about what I had seen with the framing but as soon as he heard I was an engineer he had the common response that engineers don't have any real world usefulness (or something like that) and didn't want to talk to me.
I am not really wanting to do this myself but do want to help them out. They don't have any idea of what is involved or where to find someone to fix this for them. I do most of this sort of thing myself on my own home and live just far enough from them that I don't have any suggestions for who to call. I have enough trouble finding good people to do the jobs bigger than I want to tackle for myself.
