nmk_61802
I recently installed a Liftmaster 3800 on one of my garage doors. While testing, I noticed a slight wobble, or flex in the motor while the door is raising. It is almost unnoticable unless you are working on the motor an looking right at it. Liftmaster says this is incorrect, and that I should consult the installer, well, I am the installer.
What do you guys with 3800 say is this normal? To me the motor should have a little movement to it as it is resisting the torque which it is applying to the door to open it, hence the need for the mounting bracket. Which is what I believe I am seeing
