danb35
I've been having some trouble lately with my 4-month-old LiftMaster 8500. Intermittently, it will fail to close the door all the way, reversing at some point. That point is typically early in its travel, but can be as much as 2/3 of the way closed.
When the failure occurs, the overhead light flashes 9 times. To be clear--the light is on, it turns off then on rapidly nine times, then off, then on steady. The manual says that this indicates that the cable tension monitor has been triggered.
I'm able to watch the monitor device as the door opens and closes, and the cable tension remains pretty steady--I don't see the monitor arm moving back and forth at all. The way it's installed, the arm would need to move at least 1/2" to trip the microswitch in the monitor base.
I detached the cable tension monitor wires from the opener and checked for continuity--it measured an open circuit. When I tripped the microswitch inside the monitor, the resistance didn't change.
Am I right in thinking I have either a defective cable tension monitor, or damaged wiring to the monitor? Or should I be looking elsewhere?
