Don Nguyen
- Joined
- Aug 13, 2015
- Messages
- 52
I have an 8500w that I wanted to install, but there isn't an outlet nearby, as the story typically goes. I saw that the older 8500 model had an alternative power system (580lm), which was able to power the garage opener using a low voltage 24v transformer. However, it doesn't look like this would work directly. Does anyone who have an 8500w was able to get the 580LM unit to work?
The distance from the outlet to the motor is 15'. I am not sure if it would be safe to change out the original power cord to one that would be the length I need? Any other alternatives to consider before having an electrician come by to install an outlet closer?
