Nortonscustom
- Joined
- Jun 5, 2008
- Messages
- 375
Wanted a light duty jib crane to mount to a wall post. Plan was 200lb capacity with 10' reach and 180* swing. Friend of mine gave me a new 120v hoist he had no use for. Little overkill but the price was right.
Made the bits for the hinges that mount to the post.
Next dug through the misc bearing bin and came up with a trolley for the hoist.
Welded up and painted the hinges and trolley.
The boom is 2"x 2" tube. Milled a plug that is welded into end of the tube on the hinge side. The top brace is 3/4" rod. The spoon looking deals get welded to the hinge side of the rod. The other side of the rod is threaded.
Boom and upper brace welded and painted.
After installing the jib crane I stuck the lift magnet to my welding table (which is around 2000lbs) and stalled the hoist at 450lbs. Everything behaved as it should. I'm confident it'll be drama free lifting vises and awkward bar/sheet stock around.
For cable management I used an old cord reel that the latch broke on years ago. Knew I'd find a use for it some day. Works slick.
Had it up for a couple weeks now and its been super handy. Wish I had done it years ago.
