Light duty rail hoist
Ron_J
Central PA
I decided to add a light duty hoist to my garage ceiling. I bought a track for a sliding barn door (450lb limit) and plan to pick up a 400 pound electric hoist.
My problem is I can't decide if I want the track to run the center of the bay with the lift, or the empty bay. 400lb won't be enough to lift a motor or such, so I'm not sure there would be an advantage to having it over the lift.
Anyone do anything similar or have any thoughts on the matter?
zippyslug31
Central Oregon
I don't have a ton to offer, but I'll just toss it out there that if I was going to install a hoist, I'd want it to be movable along both x and y axis, such as this. I saw this video a while back and thought the idea was pretty cool and would offer the most flexibility.
oldmachinenut
Missing, presumed dead in central Pa.
This is the one in my shop, actually 2 separate rails. I used 1 5/8” Unistrut supported every 28” with trolley hangers from McMaster Carr. The actual trolleys are Unistrut 600# capacity. The Dayton cable hoist is rated 500# and the small chain hoist was my Grandfathers and is similar capacity. I obviously will not use this set up to pull engines, lift my 80 gallon Quincy or my Syncrowave but it is sure a blessing on my 65 year old arthritis riddled body since my 3 Sons are all grown and I need to do most projects by myself. The last pic is my bench base, Craftsman 10 drawer 40” wide cabinet with a Harbor Freight side drawer cabinet on the end and a Snap-On wall cabinet on the back. I made a wheel carriage to support the whole unit and the rail hoist easily lifted the whole cabinet.
matt_i
Personally I'd keep it out of the lift bay and put in an open bay. If you ever were working on a car and needed it for a project or to unload a pickup truck, etc, you'd be blocked.
Also the ability to trolley the load will be potentially blocked by the upper crossbar/cable track of the lift unless you have really tall ceilings.
R
Ron_J
Central PA
Thanks all. I am planning to run a 2x4 above the trusses then attach the tracks to that 2x4 with through bolts. (and we can skip the "the trusses aren't designed for that" discussion. that's not why I started this. After all, we are talking 400 lbs spread over 8 trusses)
After a little more thought, I think I am going to put it in the open bay. Not sure what I was thinking, but it wouldn't do me much good to put it in an area that I can't use when the garage doors are up, so that means I'd have to back the whole way thru the lift to get anything out of the back of a truck.
I considered a gantry. We had one at work for a while, but it was always in the way. Both when in use and storage. Definitely better than nothing, but I didn't care for it.
Innovate1
I would just suggest going to something a bit bigger than 2 x 4. You are right the load is light but for the span it will flex a little and most of the load will be on the closest trusses. Still not much as only 200 lbs per truss for the closest trusses if they support it all.
I am setting up a fixed lift point (no track) and plan to put the "beam" to spread the load to multiple trusses in the bottom of a V where the truss bracing meets with a cross piece several inches above the bottom cord and bracing to keep the 2 x vertical. I figure that 200 lbs per truss is acceptable for temporary loading since it is like me standing on a truss and no one gives a thought to walking around on the trusses.
One thing I didn't quite follow was how everything fits together. Track below the bottom cord and 2 x to spread the load perpendicular to trusses and track above the bottom cord? Or is the track perpendicular to the trusses?
matt_i
After all, we are talking 400 lbs spread over 8 trusses.
I don't think that's valid to claim that point, a unistrut simply isn't rigid enough to transmit the load to a large group of trusses.
You should plan for the load to be shared by two trusses if the midpoint can be enforced (parallel) or 1 truss if the monorail is running perpendicular to the bottom chord.
Innovate1
Definitely cool video but not something worth the effort for me.
