Light suggestions
Jslys13
akron ohio
Hello I am looking for help with lighting for my 32x40x13.5 garage. I have read numerous threads about lights and when I think I have it figured out something changes my mind. This shop will be used for woodworking and mechanical type work. I want it to be bright and not have any regrets. I want to put up as few fixtures as possible and have great lighting.
I'm looking at these lights
https://www.primelights.com/shop/it...highbay-fixture-88-watt-clear-pl-4srhbld88fmc
Or these.
https://www.homedepot.com/p/Commerc...-000-Lumens-5000K-Daylight-50232161/302456569
Thanks for your help.
cybrdyke
USA
Of those two, the HD one would be better, although I'm no fan of Commercial Electric. Look for the same style fixture from TechBrite, Eiko, Satco, etc.
No point using a tubed highbay in new installations. Also, it's way overpriced.
CD
J
Jslys13
akron ohio
CD
Thanks for the info. I'll look into those brands.
Platonic Solid
CT-USA
32x40x13.5
12 fixtures minimum 3x4 layout (10'8" x 10' fixture center to center spacing)
Target = 94 fc @ 30" workplane
13,500 Lm per fixture (medium distribution) = 95 fc
16,400 Lm per fixture (medium distribution)= 115 fc
Lowest cost fixture option I know of see this thread
u2slow
BC
For that ceiling height, I would probably go with the 1'x2' LED rectangle panels, mounted right on the ceiling. Run EMT between them.
My shop has 19+' ceiling so I'm leaning toward the 'UFO' style pendants.
J
Jslys13
akron ohio
32x40x13.5
Thanks can you recommend a surface mounted highbay light ?
Platonic Solid
CT-USA
You can ask if they have surface mounting brackets available for previous links or
Same style fixture + add optional surface mounting brackets:
https://www.beeslighting.com/LHB-110W-U-50K-D10 $99
https://www.beeslighting.com/LHB-SMB2 $20
= $119
or
https://www.ledlightingwholesaleinc.com/LEDFHB90-5K-MVDIM-V2-p/ledfhb90-5k-mvdim-v2.htm $82.50 + Diffuse Lens adder $6.25 + surface mounting kit $5 = $93.75
or
Looks like Greenlightdepot has linear fixtures with surface mounting brackets:
https://greenlightdepot.com/collections/led-linear-high-bays
J
Jslys13
akron ohio
= $119
or
or
Thanks for all your help.
realhunter
Indiana
= $119
or
or
Exactly what i did.... bee's lighting
30 x 40 x 12 building. Very bright, easy to install, excellent quality.
I'd do 8 fixtures in your size...
Picture a bit fuzzy
Platonic Solid
CT-USA
realhunter - Your fixtures are pendant mounted. Surface mounting is fixture back flush with ceiling. 12 fixtures in a 32x40x13.5 is minimum for even light distribution. Any less and you sacrifice even distribution and will have more shadows.
Cairo94507
Auburn, CA
Whatever you believe you will need, if that is 8, I would go with 12. As we get older our vision begins to fail. You will not regret going with more lights. If you are worried about too much light, split the 12 into 3 switches. I did my 3 car garage with 2x2 LED ceiling mount flat panels and I used 40 of them broken up into 3 switches and I absolutely love the light. The garage is completely finished and everyone who sees it loves the lighting.
realhunter
Indiana
Thanks, since I bought them and installed them I am aware :thumbup:
I was referring to the lights themselves....
