Tagging onto this old thread...
I have limited space between an outside entry door and built-in cabinets/wardrobe (on the handle side, where the switches should be).
The door frame is double 2x4's as described above. Can I attach the 2-gang box with switches directly to the king 2x4?
If I attach another 2x4 to the door frame, the space is too tight to fit the switches comfortably. It could work, but it looks like an afterthought. I need a 2-gang box since that location also will control exterior lights.
I have wide (4-7/8") door molding and would rather trim a bit of the cover plate on the molding side rather than having it too close to the built-in door.
Thoughts?
Thanks.
