swimrr
I have an old twist style dimmer switch that controls the light in my dinning room. I am going to change the light to a fan and therefore need to change the dimmer to a regular on/off switch.
When I took the old switch out from the box I found that there were 2 black wires going into the switch, a ground wire going into the switch, and the white wires (common I think) were just pig-tailed in the back of the box.
Is this a 3-way switch? If so, I have no idea where the other switch is for this fixture.
The new switch has 2 brass screws and a black screw and no ground screw. Do I just connect the two black wires to the two brass screws and leave the ground wires pig-tailed to each other and the white wires pig-tailed to each other in the back of the box?
I also have another dimmer switch in the bedroom that is more simple. It has a ground, a black and a white wire. However, the new switch only has 2 screws. I've read that in Canada none of our switches have ground screws but I'm not sure if that's correct. If so, how does the switch get grounded?
I've changed plenty of switches but haven't run into these issues before. Obviously I'm more of a noob than I thought and want to make sure I get these wired correctly. Thanks in advance for your help.
