exranger06
I have a light switch in my laundry room that does nothing. It had power connected to it, which I disconnected. Even with the switched leg disconnected, everything in my house works. I have tested literally every light and outlet. And yes, I'm aware of the tabs on outlets. I tested both top and bottom outlets and EVERYTHING works. It's not a 3 way switch, just a double pole. So whatever the switch controls, it's the only switch that controls it.
How can I trace this switched leg and find out where it goes? It's a 14/2 Nm-b, neutral is still connected, hot (switched) leg now disconnected.
I wouldn't be surprised if the wire went to some random light fixture or outlet box and was just capped off not connected to anything. I actually already ran into that once before in this house. It was a 4 gang box next to front door, 4 switches - 3 switches control lights, 4th didn't do anything. The switch was connected right to the feed, then there was a 14/3 with the black also connected right to the feed. The red wire in the 14/3 was the switched leg. Found out the other end of the 14/3 went to the crawl space under the stairs to a junction box. Box just had the doorbell transformer on it, black wire was feeding it, red wire was capped off, doing nothing.
This laundry room switch is harder to figure out though. Is there a tool I can buy that would make tracing the wire easy?
) and maybe put a receptacle in the box if that even sort of makes sense for the location.
